Magnefine "inline" filters
Old Apr 19, 2009 | 01:19 PM
joe blow's Avatar
joe blow
I was snooping around and found these inline filters for the p/s system and the transmission. They are a universal filter with a built in magnet. They look like a cool little setup. Anyone ever hear of these or use them on their vehicle....Any good luck with them?
Magnefine--Your Source For Magnefine Inline Filters
Thank you
Old Apr 19, 2009 | 01:36 PM
juneau76's Avatar
juneau76
Jeff (Beachbumcook) posted a thread about this not too long ago. A bunch of people jumped all over it as it is a GREAT mod. I say go for it. I've been waiting for the weather to cooperate with me before I did it since I can't get the truck in the garage.
Old Apr 19, 2009 | 01:38 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Check out this thread... with pictures.
I am a big believer of the Magnefine filter.
https://www.ford-trucks.com/forums/8...ml#post7197232
I installed on my p/s fluid (tranny is already well protected).
I installed on the brake hydraboost line, but it can also be installed on the p/s pump return line. This is the small line from down below to the p/s fluid resorvoir tank (flow is from pump to p/s fluid resorvoir - so install filter in right direction).
I sucked out the old fluid and refilled a few times over a week to ensure clean fluid... then before refilling the last time, I installed the Magenfine filter.
In the link above are pictures I took of my install.
Good luck,
Old Apr 19, 2009 | 03:37 PM
69cj's Avatar
69cj
Mine cost less than 20 bucks delivered. What can you put on a diesel that does this much good for less than 20 bucks. Absolute no-brainer in my book.
Old Apr 19, 2009 | 05:05 PM
KRDiesel's Avatar
KRDiesel
installed one on the PS a few months ago, So far so good.
Old Apr 19, 2009 | 08:44 PM
joe blow's Avatar
joe blow
They offer a couple of different ones. They have an aluminum serviceable filter and a (what appears to be) disposable model?
Beachbum,
Did I read correctly? You only installed one on your P/S and not your trans?
Old Apr 19, 2009 | 09:02 PM
Beachbumcook
Got Diesel?
Beachbum,
Yes... p/s only.
The tranny has a built in filter (in the pan) and the external by-pass filter. I figured that between the two, my tranny is well protected and the magnetic drain plug will capture the "metal stuff"... if any.
The p/s system has no filtration and I went with the plastic disposable unit for cost and simplicity. I drain and refill my p/s each year, so this is when I change the Magnefine filter.
Old Apr 19, 2009 | 09:24 PM
joe blow's Avatar
joe blow
Cool. Thank you
Old Apr 19, 2009 | 10:01 PM
riggz's Avatar
riggz
BBC did you leave the filter where you originally installed it or did you end up moving it to a different line?
Old Apr 20, 2009 | 08:16 AM
Beachbumcook
Got Diesel?
I still have it on the hydraboost return line.
At first, I was told that it flowed p/s fluid all the time... then now I have been tolds that it is when the brakes are applied... or if it is flowing, it is just less than the normal p/s return line.
I feel confident that since I am swapping out a quart of p/s each year and replacing my magnefine filter that I am well protected and with the mileage I drive each year and the city driving that I do (brake usage) that I am filtering my fluid... enough for me at least.
However, with that said... if I was to do it over again, I would install the Magenefine filter on the return hose (small diameter hose that conencts to the p/s resorvoir tank). The flow is from the pump to the tank, so install the filter in the right direction). This will give you more fluid flow and filtering capacity. I would buy 2" of tubing and just add it to the length already there. This way, if you had to remove the filter, you still have your stock hose and can just reconnect it to the resorvoir tank.
The filter is high-quality and built very well. There is a pressure relief valve built into it, so even if the filter becomes clogged, you will never loose p/s fluid flow.
If Ford approves this filter for their rebuilt tranny's... then it is good enough for me on my p/s system.
Old Apr 20, 2009 | 04:10 PM
riggz's Avatar
riggz
Thanks! Got one ordered last night.
Old Apr 20, 2009 | 04:46 PM
Beachbumcook
Got Diesel?
Money well spent... and not even a lot of money at that!!!
I think you will be amazed at the quality of the filter and how easily it installs.
Let us know what you think when your done.
Old Apr 20, 2009 | 07:00 PM
Rob.D's Avatar
Rob.D
Gonna place an order tommorrow. Nice find!!
Old Apr 20, 2009 | 07:04 PM
cartmanea's Avatar
cartmanea
I seem to remember there being a stock filter on mine in the line to the power steering cooler. If I replace it I'll use one of these.
Old Apr 20, 2009 | 09:46 PM
joe blow's Avatar
joe blow
Yes siree.........I got one coming.
Thanks for all the great information.
Joe
