AOD/E - 4R70W
Old Nov 20, 2002 | 09:55 PM
Four by Ford's Avatar
Four by Ford
AOD/E - 4R70W
[updated:LAST EDITED ON 20-Nov-02 AT 11:02 PM (EST)]Hi All
I have a 96 F-150 4X4 with the 5.0 engine and the door sticker has a "U" in the trans code. A search shows that this is the 4R70W transmission and I have found a number of other posts that also mention the AOD/E. Are these just two names for the same transmission?
I am getting a shuddering around 40-45 mph and I have heard that re-tightening the valve body bolts might help. Since I need to drop the pan, I will need a new gasket and filter and I want to make sure I get the right parts.
Four by Ford
Old Nov 21, 2002 | 12:43 AM
charlez's Avatar
charlez
AOD/E - 4R70W
The 4R70W and the AODE are different but not by much. The 4R70W has a wider gear range (hence the W) and also a different output shaft. Other than that they are pretty much the same thing.
Old Nov 21, 2002 | 01:00 AM
Ryan50hrl's Avatar
Ryan50hrl
AOD/E - 4R70W
the 4r70w also has a much more expensive filter thats only available at the dealership.
Ryan
Old Nov 21, 2002 | 07:43 AM
steve83's Avatar
steve83
AOD/E - 4R70W
The name AODE was only used for car applications; 4R70W was the name when installed in trucks.
Old Nov 21, 2002 | 02:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
AOD/E - 4R70W
The last AODE was built in 1995. They are all 4R70W now, even in cars. And as was mentioned above they are different transmissions, not just different names.
Old Nov 21, 2002 | 05:19 PM
Four by Ford
AOD/E - 4R70W
Gentlemen,
Thank you all very much for your responses! I just hate having to buy parts from the dealer (usually WAY over priced), but it doesn't look like I've got a choice.
Thanks again for the information guys
Four by Ford
Old Nov 21, 2002 | 05:27 PM
BlueOvalFitter's Avatar
BlueOvalFitter
AOD/E - 4R70W
Ryan,you can get a 4R70W filter at any auto parts store.I get mine at Discount Auto,which is a PURALATOR,for about $8.00.
Old Nov 21, 2002 | 07:05 PM
Four by Ford
AOD/E - 4R70W
Thanks FatF150, that is welcome information! I pass by an AutoZone on my way back home from work, I think I'll stop and see if they might have something that fits.
Thanks again!
Four by Ford
Old Nov 24, 2002 | 01:46 AM
Ryan50hrl's Avatar
Ryan50hrl
AOD/E - 4R70W
AutoZone and Advanced auto parts didn't have the filter available last time i was there. does anyone have the part number of the purolater one?
RYan
Old Nov 24, 2002 | 04:42 AM
BlueOvalFitter
AOD/E - 4R70W
Ryan,i will post it later today when Discount auto parts opens.I need to go buy one anyway.
Old Nov 24, 2002 | 11:35 PM
Rand's Avatar
Rand
AOD/E - 4R70W
[updated:LAST EDITED ON 25-Nov-02 AT 00:35 AM (EST)]My 1994 T-bird had a 4r70w in it.. they put it in cars back then too.. and napa carries the filter.
Rand
Old Nov 25, 2002 | 05:06 PM
BlueOvalFitter
AOD/E - 4R70W
Ryan,sorry i didnt get back to you.I went to Discount Auto,and since they've merged with Advance Auto they dont sell Purolator trans. filters anymore.So,i had to go to Autozone and got a Deausch trans. filter part#TF403 for 12.99.Pep boys sells Purolator but i dont know how much.Hope this helps.
Old Nov 25, 2002 | 05:16 PM
HiTech's Avatar
HiTech
AOD/E - 4R70W
Old Rusty Wrench
Jul 11, 2012 04:45 PM
wildcat99
15
Apr 3, 2012 09:34 AM
tintman
Jun 8, 2011 09:09 AM
farmnfly
Jan 7, 2008 06:19 PM
