I want to install a compressor (100% duty cycle, 150 psi) with a Firestone control panel for the air bags. Later, I intend to install a set of air horns. I also want to be able to air up truck and trailer tires when needed.
Is there any advantage to going with a 10 gallon air tank over a 1 gallon or 5 gallon air tank for these purposes?
The air compressor provided in the Firestone kit has very low capacity so if you intend to air up tires I would use the largest air tank that will fit under your truck.
