Air Tanks - Does Size Matter?
I've got Firestone Ride-Rite Airbags on my F-350.
I want to install a compressor (100% duty cycle, 150 psi) with a Firestone control panel for the air bags. Later, I intend to install a set of air horns. I also want to be able to air up truck and trailer tires when needed. Is there any advantage to going with a 10 gallon air tank over a 1 gallon or 5 gallon air tank for these purposes? |
The air compressor provided in the Firestone kit has very low capacity so if you intend to air up tires I would use the largest air tank that will fit under your truck.
Lou Braun |
Thanks Lou. I'm not planning on using a kit. Here's what I think I want:
Control Panel 2225 - - $98 Single guage and Pneumatic switch. White face. /w 30 feet 1/4 in air line. Compressor 9287 -$286 Super Ultimate Heavy Duty, Max Air Pressure 150 psi Duty Cycle 100% Amp. Draw 23 CFM @ 60 PSI 1.18 CFM @ 100 PSI .94 5 Gallon Air Tank 9246 - $76 9.5 in. Diameter, 20.75 in. Length, Four 1/ 4 in. NPT, One 1/ 8 in. NPT Ports, Each Pressure Switch 9016 - $34 90 on/120 off. |
