Sponsored by: Real Truck
Questions
Old Apr 18, 2009 | 10:13 AM
genebob's Avatar
genebob
Questions
Hey guys! I'm new to this thread and hope you can help me out.
I bought an 05' F350 Crew Cab King Ranch with the 6.0. How do I tell which rear end I have? Also the exterior temperature is stuck at 50. I've been told it is probably the sensor, but where is it?
Also, now the back up sensors quit working. You can have the switch on, but when you shift into reverse it shuts off. Any ideas?
Thanks for your help in advance!
Old Apr 18, 2009 | 11:34 AM
powerstroke72's Avatar
powerstroke72
The temp sensor should be behind the grill. Check you VIN decal on the door. It should have the VIN and down on the lower right corner it should have a thing that says "axle" and below it will have a code like 37 or 3L or something like that. Go to this link in the tech folder:
https://www.ford-trucks.com/forums/4...lder_____.html
Go to post #9 by IB ADRIAN and you'll find the axle codes there. The codes in this post should be for '05+ trucks so yours should be there, not in the ones higher up on the page.
The reverse sensor thing could be one or more bad sensors but I'm not sure how to check them. Do a search on this forum though because it has been discussed several times and you should be able to find something.
Old Apr 18, 2009 | 08:11 PM
Greg B's Avatar
Greg B
If it's not a dually, it's probably a 3.73:1 ratio. If it's a dually, it could be a 4.10:1 or 4.30:1 ratio. The VC label in the door jamb or on the edge of door will give you the code. If the code is all numbers, it's an open differential. If the code is a number and letter, it's a limited slip.
Old Apr 18, 2009 | 10:02 PM
420CREW's Avatar
420CREW
Great info this helps me as well
Old Apr 18, 2009 | 10:12 PM
powerstroke72
Did a little digging and here are two links to threads on the reverse sensor issue. The one on the bottom seems to be the best solution to diagnosing and fixing.
https://www.ford-trucks.com/forums/6...se-sensor.html
https://www.ford-trucks.com/forums/4...p-sensors.html
Good luck.
Old Apr 19, 2009 | 12:40 AM
Konarain's Avatar
Konarain
Can you folks tell me why, if its bad to backup a short distance (not to tear up my road) I've stopped doing it 'cause it felt weird when I engaged, drove a half mile on grass (and a little rock) and then disengaged the hubs. I only backed up a short distance with one engaged!
Thanks and Aloha
Old Apr 19, 2009 | 02:41 AM
Monsta's Avatar
Monsta
Sit. Stay.
Brah...talk about one thread highjack!
Are you talking about backing up in 4WD? There's no problem in doing that. Backing up a trailer in 4LO is actually recommended. So backing in 4HI isn't anything. If it was, a lot of people who plow would be driving a different brand.
Locked in 4WD with one hub locked isn't a good thing really. Heck, that's pretty "par for the course" with ESOF! But all the power will typically go to the wheel with the least resistance since you have a open diff up front. That wheel would be the one that is unlocked. This could create issues at the U-joint and the hub.
Why would you have only one hub locked?
So what cuz, you live Kona side?
Old Apr 19, 2009 | 01:28 PM
Konarain's Avatar
Konarain
Kona side, yeah. Backing up with one hub in, 'cause it no tear up the grass when pull out...
Tanks 'eh?
rcherry11
Oct 31, 2009 09:28 AM
Kott3670
2004 - 2008 F150
Mar 1, 2009 06:48 PM
RussB
22
Jan 31, 2009 02:46 PM
Tore
Jul 22, 2008 09:50 PM
oscar_007
1997 - 2003 F150
15
Oct 12, 2006 09:16 PM
