AL4D causeing problems
Old Nov 25, 2002 | 11:13 PM
turtle_72's Avatar
turtle_72
Ok I posted on the Bronco II forum but I am not satisfied with the answer I got. I have a '88 Bronco with a 2.9 and the AL4D tranny. Three weeks ago the tranny went out. I found a deal on a recently rebuilt tranny at a junkyard. We installed it. The transsmission shifts like a dream. But when you let off the throttle the rpms fall back to 1000 or so. It is running around 3000 rpms at 60 mph. Is this normal.
the response I have gotten is that the tranny is bad. the person i got it from is a long time freind so i trustr him
Any help is greatly appreciated
I am at a lost on this one
Curtis
Old Nov 26, 2002 | 01:30 AM
Ford_Six's Avatar
Ford_Six
Not so much a bad tranny, maybe a bad torque converter. I know my reason for running a Ford automatic was for the engine braking, and when working right, they are awesome. Did you change out the T/C when you changed the tranny? You probably should have just flushed yours and re-used it.
Jared
Old Nov 27, 2002 | 08:27 AM
Opera House Works's Avatar
Opera House Works
3K at 60 mph sounds more like it doesn't have overdrive. Overdrive is .75 to 1 and gives a big change in rpm. Torque converter locking up would only account for about 300. Try this when going down the road at a steady 60. Keep your foot steady on the gas. With left foot, gently pres on the brake. Just enough to turn on the brake lights. This will disengage the torque converter and the rpm will jump. If so then the TC is ok. I don't know why people go to junk yards. These transmissions are so easy to work on. After it is out of the car, few things are as easy to work on as an overdrive problem.
Old Nov 30, 2002 | 11:32 AM
burk97's Avatar
burk97
It sounds like a might have a late shift try changing the vaccum modulator.
Old Nov 30, 2002 | 11:57 AM
Opera House Works
put the transmission in manual (1), point it down a fairly steep hill from a stop, foot off the brake, no gas and let the engine do the braking. Engine should tach up to 2-3K with obvious engine braking.
Old Nov 30, 2002 | 04:39 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Flip4ford
Kansas Chapter
Sep 15, 2013 06:19 PM
Flip4ford
Kansas Chapter
19
Aug 19, 2012 08:12 AM
77_F150_4x4
13
Feb 23, 2008 04:39 PM
jdman1
15
Jul 13, 2007 06:03 PM
curti
Jan 1, 2001 07:04 PM
