Which Clutch
Old Nov 30, 2002 | 05:32 PM
stryder's Avatar
stryder
Which Clutch
I'm getting ready to put a 351 in my '90 F250 4x4 and was trying to figure out which clutch to get...Centerforce II or Dual Friction?
The Motor will be mostly stock, except I my go to a larger computer friendly cam. The truck is a 4spd with 410s. Main use is occasional heavy hauling/towing and daily trans.
Thanks,
Stryder
Old Dec 1, 2002 | 01:21 PM
Mike W's Avatar
Mike W
Which Clutch
I am not familiar with the dual friction. I use a diaphram type purchased from a local clutch shop in my 390. My main concern is ending up with a smooth chatter free clutch. If this is a new engine, bellhousing combo, I would suggest you check the bellhousing bore with a dial indicator to be sure it is concentric with the crank. I had one that wasn't one time and it took me 6 months to figure it out.
Old Dec 1, 2002 | 04:06 PM
2Wise4aGM's Avatar
2Wise4aGM
Which Clutch
stryder12
Bronco II
Dec 5, 2004 08:36 AM
stryder
Garage & Workshop
Sep 23, 2004 12:30 AM
stryder
Jul 28, 2003 04:03 AM
stryder
Garage & Workshop
13
May 8, 2003 11:09 PM
stryder
Garage & Workshop
Jan 21, 2003 10:24 PM
