View Poll Results: Which type of pod?
Pillar - Autometer 17306
24
77.42%
Bezel - Autometer 15003
22.58%
Voters: 31. You may not vote on this poll
gauge mounting - bezel vs. pillar
Old Apr 16, 2009 | 11:28 AM
Justin03PSD's Avatar
Justin03PSD
I am trying to decide which way to go with my gauges. I plan on getting the Aeroforce Tech Interceptor with the EGT add on, which would leave me one open analog input on it (for a wideband, trans temp or what have you). So, counting the DP remote selector at most I should only need two holes total.
Given that what I've been looking at is the stuff from Autometer. Here are the pics:
Pillar
Bezel
I like to be stealthy and don't like to advertise, so I'm leaning towards the bezel. But, it seems most people go with the pillar arrangement. I think the pillar would give better visibility while driving, but that's the only advantage I can come up with. Cost is not a factor as both are around $50, with the bezel usually a bit more expensive. They both come in black but with the bezel I'm wondering if I could get away without having to paint it since the rest of the dash area is mostly black already.
So, what do you think?
Old Apr 16, 2009 | 11:36 AM
12ozd's Avatar
12ozd
I like the bezel mount myself.
Old Apr 16, 2009 | 11:38 AM
03_PSD's Avatar
03_PSD
Going with the two choices you have, I like the Pillar.
Old Apr 16, 2009 | 11:47 AM
Justin03PSD
Keeping with the dual hole theme, if you can suggest different locations or manufacturers, please do.
I know Autometer also makes a dual overhead console pod (18016) but I was worried about hiding wires (and how long they'd need to be) with it.
Old Apr 16, 2009 | 12:03 PM
megawatt00's Avatar
megawatt00
I like the pillar between the two. You can see them out of the corner of your eye. The OHC mount is nice too. The wiring should be plenty long for that also.
Old Apr 16, 2009 | 12:31 PM
jeff7825's Avatar
jeff7825
I voted for the pillar. You have to run your own wires (at least I did) for your gauges unless you buy an already made harness from one of the sponsors, so the length for the overhead mount shouldn't matter.
Old Apr 16, 2009 | 12:43 PM
big poppa's Avatar
big poppa
I got the pillar and I would vote for the pillar if you were sticking 3 or more gauges in there. If your sticking with only 2 gauges I would say the bezel, get 3 or moe gauges, get the pillar, good luck..my .2
Old Apr 16, 2009 | 02:05 PM
Ponyboychris's Avatar
Ponyboychris
I like the pillar but also went with the under the dash 3 pod as well. Pics in my gallery.
Old Apr 16, 2009 | 02:32 PM
triskit16's Avatar
triskit16
Have you considered the F650 dash?! Just throwing another option out there...
Old Apr 16, 2009 | 02:37 PM
Justin03PSD
Sounds like some kind of swap, but I honestly don't know anything about it. I'll start searching but if you can share a link or point me to a thread that would be great. Thanks!
Old Apr 16, 2009 | 02:38 PM
guitarpicr's Avatar
guitarpicr
I like the pillar. Thats whats in my truck. Easy to see at a glance. It does make a little bit more of a blindspot, but you get used to it after a short time.
Old Apr 16, 2009 | 04:08 PM
maevans's Avatar
maevans
I have them both, pillar and bezal. I like the pillar better because it is in your line of sight, making it easier and safer to use.
Old Apr 16, 2009 | 06:50 PM
superduty4x4's Avatar
superduty4x4
F650 dash
https://www.ford-trucks.com/forums/8...f650-dash.html
https://www.ford-trucks.com/forums/8...ml#post7019796
Old Apr 16, 2009 | 07:14 PM
Justin03PSD
Originally Posted by superduty4x4
F650 dash
Right on, thanks!
That looks awesome but I don't know what I would put in the square holes in the middle, other than a bunch of blanks. Hmm...
Old Apr 16, 2009 | 08:19 PM
CSIPSD's Avatar
CSIPSD
Thedash bezel is hard to see... be prepared for that. The A pillar is the easiest to read at a glance, overhead is nice but will not work with your scan gauge... Underdash is a nice one too...
