trip computer
Old Apr 15, 2009 | 10:06 AM
chas6663's Avatar
chas6663
trip computer
2000 f-350, over head trip computer don,t work
Old Apr 15, 2009 | 10:15 AM
HKusp's Avatar
HKusp
You probably have some resistors that have come loose. Check this link click here or this one click here.
Old Apr 17, 2009 | 07:44 PM
chas6663's Avatar
chas6663
Thanks I will try it, the dealer said it was som computer, $250
Old Apr 17, 2009 | 07:46 PM
megawatt00's Avatar
megawatt00
Be careful when you pull it out the resistors are small and easily lost. Very easy fix though.
Old Apr 17, 2009 | 08:01 PM
F350-6's Avatar
F350-6
Welcome to FTE. It lights up but does not work? Do some of the other functions not work right either? Most of the time this is just from things coming loose on the computer board in the overhead display. You're options are to either buy a new display module or grab a soldering iron and fix it yourself.
The fix is surprisingly easy. Here's the instructions on how to do it. https://www.ford-trucks.com/user_gal...&albumid=19462
Old Apr 18, 2009 | 06:11 PM
chas6663's Avatar
chas6663
Thanks Again, one of the #680 was out,
Old Apr 18, 2009 | 06:13 PM
surveyguy's Avatar
surveyguy
you may want to wiggle the others. i did, and 2 were loose (2 were off too). Be carefull not to get things too hot.
After doing the work, my trip miles are still stuck, but the compass works. i hope you get it all working for you, please post back with your results, and if you have any other questions!
Old Apr 25, 2009 | 12:12 AM
chas6663's Avatar
chas6663
one of the others were loose, got it all back to gether it all works just like new, it took a couple days to get miles to empty where it should be, avg mile per gal still not right, but I only drive 12 miles to work, and I rode my bike three days this week, compass does work to, next I will tackle door locks, the pasanger front don,t work at all passenger rear works sometimes, and driver door not at all
Old Apr 25, 2009 | 02:30 AM
PaysonPSD's Avatar
PaysonPSD
Good work. Easier than you thought and you saved $250.00.
Most call that function the lie-o-meter because it does not give you an accurate avg mpg. Hand calculate to be accurate.
Old Apr 25, 2009 | 10:40 AM
surveyguy's Avatar
surveyguy
awesome! yup, took mine a couple days too. all working good now! thank goodness for FTE!!!
cajuncop21
Apr 10, 2018 11:58 PM
dkkids5
Feb 19, 2018 03:35 PM
1982_f150
Feb 9, 2011 03:56 PM
thefnswits
Sep 21, 2008 03:28 AM
shadowdd
Sep 29, 2007 10:44 AM
