trailor weight
Old Apr 15, 2009 | 07:49 AM
Greyf100's Avatar
Greyf100
trailor weight
anyone happen to know how much an '81 F100 can tow?
300-6, C6, 9"...4700lbs GVWR (5 on 4.5" BP)
std cab, long bed, 133" WB
Old Apr 15, 2009 | 08:09 AM
dustybumpers's Avatar
dustybumpers
take the weight of the truck empty, subtract it from your gvwr, and that is your leagl limit.
Old Apr 15, 2009 | 08:11 AM
Greyf100's Avatar
Greyf100
wow...thats not much...i think my wrangler has a higher tow rating
how do they determine trailor tow capacity?
Old Apr 15, 2009 | 08:45 AM
bashby's Avatar
bashby
Do you have a Reese style hitch? You should be ok with a pretty big trailer as long as it has brakes and you load it without too much tounge weight. I think youd be fine towing 5-6k lbs or so. The towing section may be of more help
https://www.ford-trucks.com/forums/forum68/
Old Apr 15, 2009 | 09:08 AM
Freaksh0w's Avatar
Freaksh0w
You sure your GVWR is 4700??? Doesn't that mean you are practically riding around fully loaded with just yourself in the truck? I'd look again, lol.
Old Apr 15, 2009 | 09:29 AM
dustybumpers
I'm thinking the same thing, holy cow a ranger has more gvwr than his half ton. check on your door sticker what your gvw is, not what your registration says
Old Apr 15, 2009 | 10:54 AM
Greyf100's Avatar
Greyf100
4700lbs GVRW
Old Apr 15, 2009 | 11:03 AM
Greyf100's Avatar
Greyf100
man even with a better camera i cant get a clear pic of the door tag...i give up..lol
Old Apr 15, 2009 | 11:18 AM
bashby's Avatar
bashby
A friend of mine went to the quarry in his 1/2 ton dodge (96 or so), when he pulled on the scales they refused to load him and told him he was over weight with just his toolbox in the back. They go by the registration though
Old Apr 15, 2009 | 12:33 PM
dustybumpers
wow, that's a light gvw. the truck probably weighs 4,000. if you have 3 adults, and weekend camping gear, you could get an overload ticket.
Old Apr 15, 2009 | 01:26 PM
dirtballer's Avatar
dirtballer
I have the same truck and i tow around 2,000bls and that's just 2" ball on the bumper you can tow more i have heard of people towing up to 4,000lbs i dont think i would.
Old Apr 15, 2009 | 03:33 PM
86bigred's Avatar
86bigred
do you have a swiss cheese frame. that might be the reason for the light gvw.my 81 f150 has 6100 gvw.
Old Apr 15, 2009 | 04:21 PM
86bigred's Avatar
86bigred
i believe that is your payload weight in the box of your truck.you need to find your gvcw. somebody here will be able to find that out for you.
Old Apr 15, 2009 | 04:35 PM
Greyf100's Avatar
Greyf100
so the GVRW would mean i can put 1000-1500lbs in the bed? that sounds about right.
i plan to put an aux trans cooler, reese hitch, 3.25-3.50 gear in the axle, and napa prem rotors with EBC pads, and 235/75r15, 255/70r15, or 245/75r16 tires.
was also planning on putting heavier springs all the way around the truck and an elec trailor brake setup.
Old Apr 15, 2009 | 05:15 PM
86bigred's Avatar
86bigred
check the trailer and towing fourms in this site.they might help.plus if you have your owners manual it should have what you can tow with that pick.it all depends on engine,trans,rearend, and suspension on the truck,for what you can tow.don't forget the tounge weight of the trailer will subtract from the weight of your box payload. good luck
