351W to 460 swap
Never used por 15 but heard its good stuff, brush it on the frame and it smooths itself out. WHen you get that 460 and zf working and you think its too much for your truck I'll trade you for my 351/c6...even up!!
Sounds like you are doing a lot of the same things I am doing to mine. I suggest putting on a set of headers on when you install the exhaust. I have a set of headman headers and with the power boost I also gained 2 MPG. Give or take a few tenths depending on wind direction and how steep the road is
Just so you know, the ZF 5-speed does not have granny low like your T-18. It is an overdrive, but no granny. You could improvise by shifting to low range in your transfer case when you need to, but it is kind of a pain to have to do that.
Since he is getting a zf that goes to a gas engine, he will probably end up with the 5.72 1st gear. While it's not as low as the older 4 speeds(did they have a low 6 1st gear?) it's close. Some of the diesel zf's had a high "4ish" 1st gear.
I swapped a 302efi for a 460efi in my 89 f-250, it has a ZF5spd. and moves right along in all gears( 5.72 OD with 3.55 originally 4.88 gears) also put a 6 inch lift, swaped the IFS front for a HPdana 44, and a pair of sterling 10.25 in the back for the 6 wheel drive
I have an 89 Super Duty with a ZF. It is my mechanic's truck with welder, compressor, crane and tools on it. It had 5.13 gears when I bought it. I think my Dad's old Farmall tractor would have outrun it. I swapped in a set of 4.10's, so it runs down the road fine, but is gutless in soft or rough ground. My ZF seems fast in both low and reverse. By the way, it is the 7.3 non-turbo diesel.
yea im definately puttin hedman headders on it...i have true duals as it is so ill make it hook up nicely. i have a pipe machine at my dads auto repair shop so it'll have a good deep rumble when its done. i also bought myself a new years present. i dont know if i told you but i bought a Dana 70 for the rear...its a monster with 4.10 gears in it. i plan to rebuild that completely, get traction bars, that ZF5, get all the body work done, get a dana 60 front, and get all the paint and body work done. I want to make my truck one crazy strong SOB! I want to pull everyone around backwards...heres how its looking so far
<a href="http://tinypic.com" target="_blank"><img src="http://i45.tinypic.com/2iqo66c.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i45.tinypic.com/256qwzc.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i50.tinypic.com/11sdvv6.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Yea I got them it has (460 CID engine only) stamped right on them =D I pulled it out of a 1985 tow truck so I got everything. But thanks for keeping an eye out and the help! It's greatly appreciated, it's nice to have yall here to notice stuff like that. =D
-Jon
-Jon
a 5-speed od? what kind of tranny is that? does it bolt on to the 460 or my 351? my dad owns an auto repair shop so i can get my hands on anything i need and i work my *** off so i make good money with him, i just have to save it. anyways....is the 5-speed strong? cuz i was always told that over drive trannys are weak. if it works with the 460 ill do it cuz with that beast ill need to get the best mpg i can. but im probably just going to do the 460 with a c6. is there any other tranny that can bolt up to that besides the E4OD because i heard those break when a 460 is on it and its not strong to start with. i want all the heavy strong stuff on my truck yet i want it to haul *** when i give it gas. i just dont want to break crap...So what do you all think?
I agree with 86 big red. I rebuilt my 92 F250, 460 and and had about $1500.00 in the motor and did all but the machine work myself. Paid my machine guy $500.00 and about $1000.00 in internals. Another $2200.00 in the SFI fuel injection set up. There are more parts out there for 351 performance compaired to a FI 385 series motor build.
