Aerostar Ford Aerostar
Front axles
Old Apr 21, 2009 | 11:39 AM
bertha66's Avatar
bertha66
Can the CV axles be removed from the van and still drive, or does the front end need to be hooked up to make it drive?
Old Apr 21, 2009 | 08:41 PM
xlt4wd90's Avatar
xlt4wd90
There is no 2wd mode in the 4wd Aerostars. The front end needs to be hooked up in order to drive the van. Otherwise, the 4wd computer will constantly try to lock the center diff, which will burn it out.
Old Apr 21, 2009 | 08:45 PM
93nighthawk's Avatar
93nighthawk
Yes you do need the front end hooked up, otherwise all of the power will go to the front wheels (path of least resistance) sense the transfer case is an open dif basically.
Old Apr 22, 2009 | 12:43 PM
bertha66's Avatar
bertha66
That is what I thought, so I will be pulling the axle out of the parts van and putting it into this one.
Old May 11, 2009 | 07:25 PM
AerostarDad's Avatar
AerostarDad
Just a thought I had, and , it may not apply here, but, back in the "old days", you had to add an additive to rear end fluid when using a Posi/Sure-Grip/Track-Lok differential. If this wasnt done, the symptoms here would appear. Do Aero*'s have a "posi" -type unit in the front diff?
Old May 11, 2009 | 08:48 PM
xlt4wd90's Avatar
xlt4wd90
No, the Aero's front diff is open.
The stuff added to clutch type limited slip differentials is a "friction modifier"; it's designed to make the gear lube more slippery, so that the clutche plates will more easily slide against the steel plates until some high pressure is reached, where they should lock up. It prevents the clutches from chattering when you drive around turns, and lets them live longer.
The same concept may be applied to gear-based limited slip diffs, or gears in an open diff, where you want them to be sliding all the time. But I've never tried it before. It can't hurt the gears, I guess.
Old May 11, 2009 | 08:54 PM
AerostarDad
Thanks, xlt, for setting me straight. It was just a fleeting thought I had.
Cheers!
Old May 11, 2009 | 10:55 PM
93nighthawk
aka the Stinky Stuff. Any ford parts guy worth his salt will know what you are talking about. If you have an LS rear end I would use it there, otherwise you don't use it in the front or transfer case.
Old May 12, 2009 | 07:37 PM
xlt4wd90's Avatar
xlt4wd90
Definitely not in the transfer case. Those clutches are electrically engaged, and should not be allowed to slip any more than they are designed to. Also, it just occurred to me that the lube in the front diff and transfer case should be ATF, not gear lube, and may not react well to the friction modifier.
reptar0077
Jan 6, 2016 07:12 PM
wrhatt
1978 - 1996 Big Bronco
Dec 7, 2015 12:16 PM
5.0 Heaven
Feb 12, 2013 07:21 AM
DuallyBoy
Offroad & 4x4
Dec 2, 2002 01:54 PM
ARTURO TOSCANO
Aug 19, 2002 12:43 PM
