1978 - 1996 Big Bronco
Bronco 4WD with open diff.
Old Nov 27, 2015 | 09:09 PM
wrhatt's Avatar
wrhatt
I'm looking at a 1992 Ford Bronco with a 5.0 V8, automatic transmission, and an axle code of 19. If I understand correctly this is the 3.55 open differential and if I'm in mud 1 rear wheel will spin and 1 rear wheel will do nothing. My question is what do the front wheels do in four-wheel-drive in the mud? Will 1 front wheel also spin and 1 front wheel do-nothing or does the front axle, regardless of the rear type axle, have limited slip and both front wheels will pull? Thank you.
Old Nov 27, 2015 | 10:43 PM
Conanski's Avatar
Conanski
LS front diff was a special order only so not very common. With open diffs you will only get 1 wheel on each axle driving in slippery conditions, the other will sit there and do nothing.
Old Nov 28, 2015 | 09:40 AM
wrhatt's Avatar
wrhatt
Thank you.
Old Nov 28, 2015 | 11:46 AM
brocluno's Avatar
brocluno
If you are contenplating adding posi, it's a good idea to use a "soft" posi on the front. You can get as aggressive as you want on the back.
But if you live/drive in snow/ice an aggressive rear posi will sometimes just shove you straight ahead, or break the rear loose easier as one wheel will break traction in a turn just from the internal clutch lock vs little resistance from ice and then as soon as you give it any power, it will break the other one loose, so you go sideways easily
ARB Air Locker is a good choice for the rear with a soft posi in front
Old Dec 7, 2015 | 12:16 PM
Kemicalburns's Avatar
Kemicalburns
an Elocker would also be a good choice in either diff as it works like an LS when not engaged. so you get the best of both worlds.
delorenzomp
Dec 28, 2018 12:01 PM
Pitt4212
6.7L Power Stroke Diesel
159
Apr 10, 2018 10:05 AM
hankaye
Apr 27, 2014 07:33 PM
blk04
2004 - 2008 F150
Sep 25, 2004 09:20 PM
oz9609
Feb 1, 2001 07:29 AM
