Sponsored by: Real Truck
Torqshift temp problem
Old Apr 12, 2009 | 12:50 AM
Resting River Ranch's Avatar
Resting River Ranch
I have a 2003 F350 with the 6.0 and Torqshift auto and recently I had the tranny temp spike and have the check gauges light come on. The tow/haul light was also flashing.
At the time when this happened I was just driving across town without a load, I touched the pan and there was no way the temp was anywhere near what the gauge was reading???
I started the truck up the next morning, and the tranny temp gauge was already 1/4 of the way up just after starting and within 1 mile of driving the gauge pegged again and the tow/haul light began to flash with the check gauges light coming on too.
I checked for codes, didn't find any...
Any thoughts?
Thanks!
Old Apr 12, 2009 | 07:40 AM
KSCRUDE's Avatar
KSCRUDE
I would check the temp sender. Take wire off of sender and temp should go to cold. Ground sender wire and temp should peg to hot. This test will prove that your gauge is working properly. It might also be the gauge but is most likely the sender. Gauges rarely fail so i would start with the temp sender. Slap a new sender on there and hope for the best.
Old Apr 12, 2009 | 10:09 AM
vlietracer64's Avatar
vlietracer64
Do not have any real experiance with problems with the Torqshift auto but i do know they have a thermostat that controlls flow to the tranny cooler, is it possable that the thermostat failed closed causing no cooling loop and the tranny is actually overheating, again i do not have much knowladge just know what i have read. I guess you could use a infread heat gun and check pan and or cooler line temp. Just my .02 cents. Let us know what you find.
Old Apr 12, 2009 | 03:50 PM
rob17's Avatar
rob17
I'm kind of surprised to here that there's a thermostat for the transmission cooler. My ScanGuage monitors my engine and transmission temperatures. When it's cool out my transmission temperature runs cool (135-145) and it's warm out it will runs at a higher temperature. When I run with my fifth-wheel the transmission runs around 180 + or - 10 degrees. In contrast to the engine, which obviously has a thermostat, runs 190-195 all the time.
Rob
Old Apr 12, 2009 | 04:36 PM
MassSupra's Avatar
MassSupra
Same problem here, scanned it at Ford and I'm getting an intermittent high temp input from the sensor, It will take a few minutes for it to shift into OD on the highway sometimes and gives me a rough 1-2 and 2-3 shift sometimes. I've got a new sensor just haven't had the time to switch it out.
Old Apr 12, 2009 | 05:58 PM
vlietracer64
Rob
I see the same results when towing in warmer or cooler weather, the fluid never stays at a constant, i see 160 towing 12,000 in 50* but then see 180-190 during summer towing. But i know i have read on this post and was told by the dealer that is why you have to use a heated tranny flush machine to flush the tranny, if it is not heated the thermostat stays closed and you never full cycle the old fluid out of the cooler. Just my suggestion for what could be wrong. Again i have not had the pleasure to do any repair`s to the torque shift tranny, just going off little bits of info i have come across, hope it help`s. Maybe the thermostat is just like a bypass cooler, increases or decreases flow when needed, but their would always be a flow, kinda think their would have to be a constant flow to the cooler???? not really sure.
Old Apr 12, 2009 | 10:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a thermostat in the TorqShift. It's in the pump body, and it's nominal temperature to open is 165F.
When it's closed there is still flow to the cooler, but it's reduced by 90%.
Old Apr 12, 2009 | 10:46 PM
rob17's Avatar
rob17
Thanks Mark, I was hoping someone would have a definitive answer.
Rob
Old Apr 13, 2009 | 02:21 PM
Resting River Ranch
Where is the wire located? I belive the sending unit is on the valve body inside the tranny pan.
Thanks
Old Jun 11, 2009 | 06:57 AM
Sabian's Avatar
Sabian
hey resting river ranch, i have exactly the same issue with my 2003 f350 within a 5 km trip the tranny temp will spike and town haul will flash, i know the tranny is not overheating i have hit a speedbump and my temperature went back to reading normal then spiked again o.O? just wondering weather you changed out the sending unit and if it was the problem thx
felix4
Sep 4, 2016 07:23 AM
Oilfan94
Jul 20, 2016 01:51 PM
kx450frider617
Mar 20, 2013 11:46 PM
embry1123
Jun 24, 2011 02:50 PM
JAYSF350
Nov 17, 2009 09:19 PM
