Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Saving Rusting Sockets
Old Apr 12, 2009 | 12:49 AM
HankMurphy's Avatar
HankMurphy
Question Saving Rusting Sockets
I've been buying some used tools on eBay to fill out my collection. For decades I've gotten by with an SK 3/8" standard socket set and a motley collection of Craftsman, very little of it bought in sets.
Some of the used sockets I'm getting have rust, and I want to deal with that. So far it seems to come in four flavors:
1. Inside the hex (gripping) part of the socket. Most come this way.
2. Inside the square (drive) part of the socket. A few come this way.
3. Outside the socket, sometimes with flaking chrome and sometimes with bubbled chrome (not sure if there is a better word for it).
4. On the ratchet, on the socket retaining ball bearing (on one side of the square drive).
At the moment, I've got my latest acquisitions soaking up WD-40. What is the next step? Do you folks oil your chrome sockets or wrenches?
Mostly these are used for weekend tinkering.
Thanks in advance for any experiences you can share.
Old Apr 12, 2009 | 08:31 AM
projectSHO89's Avatar
projectSHO89
For the Craftsman sockets or tools, just exchange them. The lifetime warranty is for any reason, whether it's a good one or not.
Old Apr 12, 2009 | 10:45 PM
CheapRanger's Avatar
CheapRanger
An old machinists trick I was taught, was to go to your local Pharmacist, and order Camphor blocks to put in your toolbox. This was after you get them clean (evaporust, wd40, whatever method).
Old Apr 13, 2009 | 12:51 AM
Jermafenser's Avatar
Jermafenser
I throw rusted tools in a bucket full of vinegar and let them stew for a while.
Old Apr 13, 2009 | 07:02 AM
ckal704's Avatar
ckal704
If you are (or know a) reloader of brass cartridges, you can throw sockets into a vibratory case cleaner.
Probably want to use something a little more agressive than crush walnut media.
Some clean sand would do the trick.
But maybe try it with crushed nut media first to see how it does. Throw them in overnight and see how well they clean up with nut media. If not to your staisfaction, try sand, but do that on a Saturday so you can check them every hour or so. I imagine a long enough time in sand might take the chrome right off eventually.
But, too, and as said before, if they are Craftsman, just go get new ones and save yourself a bunch of time.
Old Apr 13, 2009 | 08:51 AM
monckywrench's Avatar
monckywrench
I toss rusted items into a container of phosphoric acid after degreasing.
Do not use with aluminum or zinc!
Old Apr 25, 2009 | 07:15 AM
GlennFordx4's Avatar
GlennFordx4
You can always get some Oxalic acid to soak them in overnight the chrome will shine like new and the rust will be gone,you can find it at Ebay in small amounts(1LB) it is also sold as wood bleach.
Old Apr 28, 2009 | 08:53 AM
SBastow's Avatar
SBastow
PB Blaster works well
Old May 8, 2009 | 07:41 PM
frederic's Avatar
frederic
I have a coffee can full of "ospho" in the garage somewhere, and every once in a while I put all my old sockets into the can in this metal strainer thing I bought at a garage sale for $2. I'm not sure what the strainer went to but it's about 1/4" diameter smaller than a full size metal coffee can and about an inch shorter. I load it up, place it in for a while then wipe them all clean. Ospho is a rust-converter that converts rust to primer, and while that might sound like an odd thing to do it does stop the rust. Most of my sockets are husky, kobalt and mostly craftsman and while I could exchange them for new ones the issue is I can't be bothered sorting between brands.
Old May 11, 2009 | 02:28 PM
Beechkid's Avatar
Beechkid
After you get em clean, the camphor works well in bad weather conditions but I always clean my tools (wipe down) with a little kerosene or if I use brake-kleen or similar product, I will take either kerosene, wd40 or to wipe them down to avoid rusting.
Old May 21, 2009 | 01:16 AM
HankMurphy's Avatar
HankMurphy
Evapo-Rust -- Greatest Thing Since Sliced Bread!
Following some of the advice above, I ordered some Evapo-Rust. I was skeptical, but now I'm impressed! I used it on an ancient Vlchek universal socket and it got the middle (joint) clean -- not shiny, that part never was, but matte gray steel. I ran across an old nail set I'd left outside for a couple of years, fully rust-covered, and the Evapo-rust really cleaned it up.
A couple of things I learned from this. First, keep the parts you are soaking off the bottom of the container -- the wire basket is a good idea. Second, clean up the parts well before you start to remove any old oil -- that impedes the process.
This is a great forum.
Cheers,
Old May 21, 2009 | 07:28 AM
jroehl's Avatar
jroehl
USE 'EM!!! If you use your sockets for some good ol', greasy, knuckle-busting work, they'll have grease and oil on them when you're done. Wipe most of it off, and they won't rust!
Jason
Treacy
May 18, 2019 01:09 PM
Rusty_S
Garage & Workshop
Jul 12, 2017 10:20 PM
losio
Jul 7, 2016 12:40 PM
lawdawg79
Garage & Workshop
Nov 24, 2015 05:34 PM
slackerintegra
1997 - 2003 F150
Oct 5, 2012 09:34 PM
