no first gear downhill
Old Apr 11, 2009 | 12:09 AM
Augusto Eguiguren's Avatar
Augusto Eguiguren
my 4.0 SOHC '98 explorer with the 5R55 trans, 4x4 AWD has this problem, when I select Low gear at a dead stop it will shift into first gear and if I accelerate it takes off normally but if I lift the gas it will just freewheel and roll away, no engine braking at all, if I give gas again it will pull again, it feels like if it had a one way clutch in the drivetrain, I need first gear because I live in the mountains and it helps a lot going downhill in rough terrain with the assist of engine braking but it does not hold at all, second gear can be selected at almost any speed and works perfectly for slowing down on the hills, OD off works fine also.
trans is OK, fluid is perfect, does not slip and shifts smooth, I change fluid and filter every 20.000 km (12.500 miles)
this friends who owns a '06 sportrac has exactly the same problem, same tranny but his is part time 4x4, he had it fixed a year ago, he says the dealer took only a couple of hours to fix the problem and said it was a gasket or something, he does not know much about mechanics but must have been something easy since 2 hours is not much, the same problem is back with his truck now.
I tried to adjust the gear selector switch (rooster) at the tranny but it only moves a tiny bit, I adjusted the bands as well but no difference, someone suggested a sprag is bad.
what could it be wrong? is this a common explorer failure?
thanks
Augusto.
Old Apr 11, 2009 | 09:51 AM
jk080's Avatar
jk080
Transmission Rebuilder
I fixed one with no engine breaking in first and no codes by replacing the coast clutch solenoid. The solenoid checked fine electrically, but wasn't working manically. If the coast clutch is not coming on you wont have engine braking in first.
You can replace it by pulling the pan, unplugging the solenoid, removing the braket that holds all the solenoids, and it will come right out.
Sorry I dont have the part# for ya, but print that picture and take it to the dealer to help ID the right one.
Name:  5R55E Valve body.JPG
Old Apr 11, 2009 | 02:09 PM
Augusto Eguiguren
Thumbs up
thank you very much, I'll do it next week, sounds like piece of cake and a trans fluid change is due in just 2.000 km so I'll do both jobs at once.
I appreciate your help.
Augusto.
Old Apr 11, 2009 | 06:31 PM
antony25's Avatar
antony25
This can be caused by a blown out low-reverse servo gasket. It is a green gasket located under the four bolt cover next to the valve body.
Old Apr 16, 2009 | 08:35 PM
Augusto Eguiguren
I'll check that gasket also, thanks a lot.
Augusto.
brushfit
Feb 19, 2016 10:08 AM
mudram99
1997 - 2003 F150
21
Jan 22, 2016 03:41 PM
1 Wheel Drive
2004 - 2008 F150
Dec 10, 2015 10:26 PM
bandlgeorge
Aug 11, 2015 11:11 AM
shylastahl
New Member Introductions
May 30, 2006 05:24 PM
