here she is
Old Sep 6, 2010 | 07:13 PM
  #31
ford005's Avatar
ford005
I think early 80's Mustang and Capri came with a 2v aluminum intake on the HO engines before they put 4v on them (82-84?)
Funny, I just got a pair of MAC mustang headers for my 351w swap. I mocked up some stock tubular manifolds and they look like they will just barely clear on the pass side between the bell housing and the frame using a 2 1/4" pipe. A good (and very cheap) source for the flared pipe and flange in 2 1/4" is the stock connection on a 86-04 mustang where the h-pipe connects to the 'cat-back'.
Old Sep 7, 2010 | 08:49 AM
  #32
Greyf100's Avatar
Greyf100
has anyone used the full replacement bed side skins from NPD? how is the fit on them?
p/n: F-27840-9BR, F-27841-9BR
Old Sep 7, 2010 | 01:58 PM
  #33
Bagbyknoter's Avatar
Bagbyknoter
just curious what became of you 300 did you junk it or do you still have it
Old Sep 7, 2010 | 02:03 PM
  #34
Greyf100's Avatar
Greyf100
its still in my truck...will be trying to sell after i swap in the 302.
Old Sep 9, 2010 | 05:13 PM
  #35
Greyf100's Avatar
Greyf100
took a trip to the local pull a part and had a couple good scores.
7 Blade HD fan
Shroud
2v C8 intake w/ spacer
power steering pump bracket
trans kick down linkage
Engine wiring harness
and i picked up a set of aluminum valve covers from a local guy.
Old Oct 21, 2010 | 09:36 AM
  #36
Greyf100's Avatar
Greyf100
well i ended up finding an '89 Mustang 302 for WAY less then rebuilding the truck motor i had. Been gathering parts, cleaning, scrubbing, degreasing, and installing them. This is what i ended up with.
'89 Mustang 5.0HO / roller motor
Edlebrock Performer 289 Aluminum intake
holley 4160 - 600 CFM carb
BBK Ceramic Coated shorty's (will probably sell to fund Flowtech or Hedman ceramic coated Long tubes)
Will be putting stock manifolds and Y pipe on just to get it running, i want to end up with ceramic coated long tubes, no cats, and hush thrush mufflers.
I should be pulling the six this weekend and thoroughly cleaning the engine compartment. Hopefully dropping the new motor in next weekend.
After the motor project will be pulling the bed off and starting body work / primer.
Old Oct 21, 2010 | 09:49 AM
  #37
FordNFishinLover's Avatar
FordNFishinLover
Engine looks great! Keep up the good work man.
Old Oct 21, 2010 | 04:33 PM
  #38
ford005's Avatar
ford005
looking good and making more progress than I am. Can't wait to see more.
Old Oct 21, 2010 | 07:02 PM
  #39
Greyf100's Avatar
Greyf100
well...tried to put the plugs i bought for an '89 Mustang GT 5.0HO (the year of mustang the motor came out of) in to heads and they didnt fit, pulled one of them out and took it back to where i bought those plugs and matched them up...turns out the motor does have 94/95 Cobra (gt40) heads on it!!!!!!!!!!!!! When i went to look at the motor i was told it had GT40's on it, but i couldn't find any numbers on them to verify, even after pulling the valve covers! They are marked just like any other e6/e7 head, but i couldnt find a casting number. Explorer gt40 / gt40p heads have gt40 or gtp cast into them, these dont.
Old Oct 21, 2010 | 07:11 PM
  #40
Greyf100's Avatar
Greyf100
so heres the run down:
'89 HO block, crank, pistons, rods, roller cam
SN Cobra heads
edlebrock performer 289 aluminum intake
holley 4160-600CFM 4V
1" carb spacer (4 hole)
'68 mustang water pump (inlet on passenger side, so i can use my 300 radiator)
68-73 mustang timing pointer
'83 truck timing cover
'81 F100 motor mounts
'83 F150 frame perches
'83 C6 flex plate
'89 Mustang balancer
'83 F150 water neck (points straight up)
'80 Bronco 7 blade mechanical fan
'81 F150 302 shroud
'81 F150 throttle cable
14x3" air cleaner (going to trade out lid for 289 HIPO lid w/302-4v sticker)
'68 mustang power steering bracket modified for truck pump
'68-73 mustang alternator bracket
'83 truck crank / water pump pullies (v-belts)
exhaust will be:
ceramic coated long tubes (i like the way they look)
thrush mufflers
2x passenger side tail pipes (one will be cut and flipped for driver side)
Old Oct 24, 2010 | 08:36 PM
  #41
Greyf100's Avatar
Greyf100
so the whole waterpump thing didnt work out....felt kinda like alice, dropping down the rabbit hole. So i bought a truck water pump, radiator, hoses, etc. Apparently the '68 mustang pump has the water pump shaft 1" lower then the truck one, so none of my pully's fit. I couldn get any of the brackets to line up either.
So a few progress pics:
ready to pull...
lots of room...
yup, she's in there...
Now the bad news...
Something happened after installation went smoothly. I went to rotate the motor back to TDC and the crank wouldn't turn. So we began to loosen the bell housing bolts and heard a "pop", and the motor began to turn. Went to torque everything back down and heard a big "POP" and found a broken bell housing. So at some point this week its all coming back out to figure out what the heck happened.
I've looked at doing an AOD swap now, but dont want to deal with the TV adjustments. New crossmember and driveshaft. So, i'm looking for another SBF C6.
Just need to sell off some of these spare parts so i can buy one....
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
DaXman
Jul 3, 2015 05:38 PM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
sealboy84
New Mexico Chapter
Sep 24, 2008 12:18 PM
Red Star
Ford vs The Competition
30
Aug 4, 2006 10:44 AM
