here she is
Old May 9, 2009 | 08:04 AM
82-100's Avatar
82-100
Nice truck man, I really like the wheels and interior.
Old May 9, 2009 | 07:32 PM
CDF302v8's Avatar
CDF302v8
Nice old truck!
Old May 9, 2009 | 07:42 PM
Greyf100's Avatar
Greyf100
thanks guys...
prolly around the end of summer i'm going to paint it, thinking about going with the dark grey and putting the chrome trim back on.
today i changed the leaking oil pressure sending unit, and power bled the brakes.
tomorrow going to reseal the windshield after work.
Old May 9, 2009 | 07:46 PM
Greyf100's Avatar
Greyf100
oh yeah she bit me today...
i was spraying some belt dressing on, and got a bit too close to the alternator fan (rad fan sprays it too much if you hold the can back).
the alt fan peeled about 1/3 of my right middle finger nail off.
there was no need for that, i've been nothing but nice to her...
Old May 9, 2009 | 07:55 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
She didn't like that belt dressing... Don't blame her, I don't like it either.
Fortunately it was just a fingernail and not the finger, so she wasn't that mad!
-Enjoy
fh : )_~
Old May 10, 2009 | 12:22 AM
hittman1422's Avatar
hittman1422
yeah my buddy almost lost his finger that way.... got it reattached though....
Old May 10, 2009 | 01:36 PM
LCAM-01XA's Avatar
LCAM-01XA
My Chev used to hit me with the engine fan all the time, it didn't have a shroud so it was pretty hard to judge distance with my attention elsewhere - painted the fan bright friggin orange, never had issues ever again. Gotta do the same to my Ford now cause she got me a few times too, only this time it will be bright friggin blue
Old Sep 3, 2010 | 01:13 PM
Greyf100's Avatar
Greyf100
hey to bring up OLD posts, figured i'd update this one instead of starting a new. Since i lost all the old pics we'll start with fresh ones...
so the updates:
redid the entire braking system...the only thing left from 1981 are 3 hard brake lines, a power brake booster, and the forward most ebrake cable i replaced everything else with new.
been tweaking the motor a bit and drove it 2.5hrs down the highway and avg'd 17MPG @ 67mph, i was quite pleased with that. This was with c6, 3.25:1, and 225/75r15 tires. Wasnt quite as good coming home as i had 500+ lbs of motor in the bed, still managed 15MPG @70mph.
As for the motor, after looking and researching building the 300 i finally decided it wasnt what i wanted. So i found an E0AE 302 complete and running, with the frame perches, and the correct flex plate for 302/c6 for $125. This past week i have been tearing it down for cleaning and inspection.
The next pic is kinda disgusting (please cover your children's eyes or have them leave the room...or better yet tell them this is why they should change their oil regularly!)
The entire top of the motor looked like this when we started pulling it apart, which really took me by surprise as the motor ran perfect before we pulled it. Idled @ 350RPM without the faintest knock or tick, and ZERO smoke.
So this past week we spent cleaning, scrubbing, dipping, washing, and wire brushing.
The motor is in need of rod / main / cam bearings, but the cyl walls were in great shape. There was also VERY LITTLE ridge at the top of the walls so the crank will get polished or turned (depends on what the machine shop says) and new cam bearings pressed in.
As for those heads, who wants smog heads..lol A family friend had a set of 1965 Mustang 289 heads laying around, that he let go cheap. They only have 50miles or so since rebuild on them and already had 3a valve job and 1.94/1.60 valves installed. The only thing they need are guide plates and screw in studs put in. They are small chamber early style heads which should put me somewhere are 9.5 - 10:1 compression with the flat top pistons in the block.
The cam i'm going to use is the comp cams XE256H
specs:
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,000-5,200
Intake Duration at 050 inch Lift 212
Exhaust Duration at 050 inch Lift 218
Duration at 050 inch Lift 212 int./218 exh.
Advertised Intake Duration 256
Advertised Exhaust Duration 268
Advertised Duration 256 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.484 in.
Valve Lift with Factory Rocker Arm Ratio 0.477 int./0.484 exh.
Lobe Separation (degrees) 110
should make for a decent truck cam, im not building a high RPM motor.
I'll be using a 2v Holley carb from a 1969 mustang, and im trying to find a FORD aluminum 2v intake (do they even have one?)
Just for fun i sand blasted and painted one of the valve covers.
After i get the motor done and in the truck the next thing will be some body work and paint... I hope to have the truck under prime atleast by spring.
After that, f150 springs (coil / leaves), and wheels / tires... Anson Sprint wheels most likely 15x7 and 30x9.50r15 tires, and Have the bed Line-x'd!
Old Sep 3, 2010 | 01:18 PM
Greyf100's Avatar
Greyf100
here are the wheels, for those that dont know what they look like...
Old Sep 3, 2010 | 01:27 PM
Greyf100's Avatar
Greyf100
oh yeah, i almost forgot....the set of headers that were donated by a local board member!
BBK ceramic coated shorty's for a fox mustang..
Old Sep 3, 2010 | 02:53 PM
Fordzilla80's Avatar
Fordzilla80
Sweet man! Can't wait to see it come together.
That interior looks really good for the year. Your seat is the same as the one that was in the truck I got my interior from. Too bad some idiot took the seat out of the truck before I got to the interior.
Old Sep 3, 2010 | 02:56 PM
Greyf100's Avatar
Greyf100
the seat is torn and the foam is broken down, its hell on your back on longer trips...kinda looking for a more comfortable bench or buckets but black seems to be really hard to find..
Old Sep 3, 2010 | 03:37 PM
  #28
Fordzilla80
You're not kidding. You could try an older F600-F800, if you're wanting an all vinyl seat. Alot of them were black. I'm not sure if they bolt up or not though.
I don't know much about the newer seats, but I can say that my Ranger Lariat seat is 6 times more comfortable than my original. The original was exactly like yours, just tan.
Here's a pic of the two together. I think there's more foam in the Ranger Lariat seat. Now to only have it recovered in black to match my interior.
Old Sep 6, 2010 | 03:39 PM
  #29
roadrash63's Avatar
roadrash63
hey
where did you get that steering wheel ?
from a mustang looks good!
Old Sep 6, 2010 | 03:42 PM
  #30
Greyf100's Avatar
Greyf100
My father in law gave it to me, but yes I think its the optional "sport" steering wheel from a mustang.
