fluids?
Old Apr 14, 2009 | 07:58 AM
Tees77f150's Avatar
Tees77f150
Thanks Bill, this makes perfect sense. Two more questions then, is my manual wrong, or did Ford revise the fluid to MERCON from the original type F? Lastly where can I get one of those parts catalogs? I am guessing it is on CD? Yeah I know thats three questions, but I appriciate your impute.
Old Apr 14, 2009 | 09:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Since the catalog listing for A/T fluids doesn't list a (truck) serial number or (car) production date change, MERCON was used from the beginning of the 1977 model year run.
My guess is, you have an early edition of the '77 shop manual. There should be a printing date on the front or back cover or at the bottom of the first page.
The 1973/79 Ford LIGHT Truck Parts Catalog is available on a CD from hipoparts.com
Make sure you get the LIGHT truck parts catalog, the heavy catalog is F600 and larger trucks.
When you get the parts catalog, in the TEXT...look for the Paint Section.
Scroll thru the pages till you come to APPEARANCE & MAINTENANCE MATERIALS section, then look for the fluids.
Old Apr 14, 2009 | 10:19 AM
berry1234's Avatar
berry1234
Watch out for "pink stink," the burned odor that indicates trouble inside an automatic transmission.
This testing method indicates many troubled areas......
I wonder if it is best to 'flush' a tranny that is so old. I have heard good things and not so good things after a flush.
Old Apr 14, 2009 | 10:26 AM
bmuhlbach's Avatar
bmuhlbach
I would try for mercon I don't know if it matters but in the Escape forum people had issues with the mercon 5 swellling up there seals.I believe they improved the mercon5 but to be safe look for the mercon.
Old Apr 14, 2009 | 11:01 PM
Tees77f150's Avatar
Tees77f150
Thanks, I checked it out and I am going to order one up ASAP!!
Thanks again!!
colman
Jul 14, 2013 02:34 AM
rjrapp85
Nov 23, 2008 10:41 AM
tag187
Jul 19, 2008 09:02 PM
Trickedout420
Feb 19, 2007 09:04 PM
td351w
Aug 28, 2002 01:32 PM
