I'm not sure what ESOF is, but regardless, I have 2WD, so I guess this panel is available.
As for all three gauges, I'm not really sure I need them. I'm not planning to race or submit the truck to excessive torment. The most I do is tow a 5000 lbs travel trailer during the summer, and very seldom in the mountains.
So, I don't really think a chip is gonna help me much, but I'd be happy to hear your suggestions. And, for the same reasons, I don't think I need the pyro and boost gauges.
So, I don't really think a chip is gonna help me much, but I'd be happy to hear your suggestions. And I don't think I need the pyro and boost gauges.
What do you think?
With the Performax setup I went with it's relatively easy and cheap to add gauges. The first one is the most expensive.
By the way ESOF is Electronic Shift On The Fly. It is a little switch in the dash that actuates the vacuum hubs and puts your truck in 4 wheel drive.
That is compared to a manual transfer case where you get out and engage the hubs and use the lever in the floor to change ranges.
