2barrel or 4barrel?
Old Apr 13, 2009 | 03:58 AM
  #46
91Bronc300's Avatar
91Bronc300
It's the axle code in the door jam. Usually a single letter, sometimes two. For example: Axle code M could be a ford 8.8 with 3.55. Axle code NB could be a ford 10.25 with 4.10 and a posi.
I'm pulling those letters and numbers out of the air, but that's the general idea. You need a factory service manual to look the codes up. I have the 1984 and 1991 factory service manuals. They are good for a few surrounding years. If your truck is around those years I'll try looking them up for you.
Old Apr 13, 2009 | 04:00 AM
  #47
flipklos's Avatar
flipklos
If I remember right my 96 had an axle reference in the owners manual.
I know my 85 does.
Old Apr 13, 2009 | 05:04 AM
  #48
kernel-panic's Avatar
kernel-panic
Unless the axle has been worked on and the person didn't lose the tag, there should be a tag held by one of the differential cover bolts. It will have the gear ratio on it:
3 73 - 3.73 gears
3L73 - same, with a limited slip carrier
Or something similar to that.
Old Apr 13, 2009 | 05:13 AM
  #49
kernel-panic
Originally Posted by 1 F150dude
No cats. It's old enough to be exempt.
Your truck is a pre-1975? Can't remember if it was '75 or when they first started installing cats at the factory. If cats were part of the original equipment, then it's NOT exempt according to Federal emissions law, period.
Old Apr 13, 2009 | 03:16 PM
  #50
1 F150dude's Avatar
1 F150dude
In Texas anything older than 85, you can cut the cats off and remove the smog control.
Old Apr 14, 2009 | 04:07 AM
  #51
kernel-panic
I beg to differ. Texas follows Federal standards for their inspections. Some stations 'look the other way', but the way their inspection guidelines read, if it came from the factory with it for emissions control, it must be in place and working. Do you need the references?
Old Apr 14, 2009 | 12:00 PM
  #52
okwaho1650's Avatar
okwaho1650
So efi exhaust, 4v intake, 4v carb, and a little head work and got will see an improvement
Old Apr 14, 2009 | 12:06 PM
  #53
AbandonedBronco's Avatar
AbandonedBronco
Much improvement.
Old Apr 14, 2009 | 12:32 PM
  #54
6CylBill's Avatar
6CylBill
I checked out your gallery. That's one mean looking '77 dully. How does that 300 handle in such a large rig? What are you geared?
Old Apr 14, 2009 | 07:20 PM
  #55
1eyedjack's Avatar
1eyedjack
OK, I got my tag off of my rear axle, after wire brushing off some of the rust, hahaha . I have a number.. it's " 2 72 D7 A AF
603869 7 "
Does this make any sence to you guys? I have a 77 f150 custom 2wd with a 300inline,c4 AT. Would that tell me if I have a dana 60? what gears Im running? I have nooooo clue
Old Apr 14, 2009 | 07:35 PM
  #56
6CylBill's Avatar
6CylBill
From the axle tag you gave us it looks like you have a 2.72 gear ratio. These gears are designed for highway mileage and pair up best with tranny's with no over drive.
You can go over 100 MPH with that high of a gear ratio!
Old Apr 14, 2009 | 08:38 PM
  #57
1 F150dude's Avatar
1 F150dude
You do not live in Texas so do not try and tell me what the law is. I have lived here for 31 years, been building cars since I was 12 years old. So I know what the emissions laws are here.
Old Apr 14, 2009 | 08:56 PM
  #58
flipklos's Avatar
flipklos
Sure I live in ND. The emissions laws consist of "You need to install an exhaust I cant see through", "Glass packs arent street legal on a fuel injected vehicle; youve one week", and "Dont rev it up in town".
It may be siberia, but its got its pros. Cheep gas, no emissions laws, and miles and miles of empty two lane blacktop.
Old Apr 14, 2009 | 09:22 PM
  #59
1 F150dude's Avatar
1 F150dude
Out here the state is very laid back on emissions. Unless you live in Houston, Dallas, Ft. Worth. Thats why i like living in po-dunk!
Old Apr 14, 2009 | 09:24 PM
  #60
Harte3's Avatar
Harte3
The Federal emissions standard is the same regardless of which state one lives in. The administration of those standards can be quite different from state to state.
