Steering lock adjustment?
Old Apr 9, 2009 | 12:53 PM
J1MMY's Avatar
J1MMY
I guess I'm going to come under fire for this but I need LESS steering lock due to going lower with the truck and using positive offset rims (for more tuck when lowering). Any suggestions? I'm running the std box setup at the moment.
Old Apr 9, 2009 | 06:34 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I'm not sure I understand, however, I think you are wanting the turning radius of the front wheels to be shorter than it is now. IE: the front wheels won't turn as far from stop to stop.
The Spindle Arm stops are pressed into or are a part of the twin I beam. This is how steering radius is controlled.
There is no adjustment.
You would need to find longer stops and have them pressed into your existing Twin-I-Beams, if possible.
Spindle Arm Stop Specifications. 1981-F-100/F-350
F-100 : Kingpin and Ball Joint = 36.5 Degrees
F-150 : Kingpin = 36.8 / BallJoint = 36.5 Degrees
F-150 : Balljoint 4x4 = 36.0 (34.0 with 10x15 size tires)
F-250/F-350 : kingpin and Balljoint = 35.0
F-250 4x4 : Balljoint = 33.4
F-350 4x4 : Balljoint = 30.4
Hope this helps.
Old Apr 9, 2009 | 10:23 PM
sckootter16's Avatar
sckootter16
about the steering
I have a 81 ford f-150 I just but a 4 inch suspention lift under her and changed all the steering components. But I have a question when I turn the wheele to the right I get like 2 and aa half turns of the steering wheele and when i turn left I get 1 and a half yes I need a front end alighnmenst but could there be something else wrong or is that normal ? let me know please
Old Apr 9, 2009 | 10:37 PM
Franklin2's Avatar
Franklin2
Turn both tie rod end adjustments to re-center the steering box.
Old Apr 9, 2009 | 10:51 PM
sckootter16
I dont understand please explain more
Old Apr 9, 2009 | 10:52 PM
sckootter16
when I get it alighned if i tell them that about the steering will they fix it
Old Apr 10, 2009 | 02:35 PM
81-F-150-Explorer
Yes, some shops will.
Ask them to adjust the steering wheel/box centering along with the wheel alighnment. It will cost you extra though.
Old Apr 10, 2009 | 10:28 PM
Franklin2's Avatar
Franklin2
The tie rod end adjustments will shorten or lengthen the steering linkage length on that particular side. So picture this;
Both wheels are straight ahead and the steering wheel is locked in place. You go under the truck and shorten the driver's side linkage by 3 turns. So the driver's side front tire now points toward the center of the truck(or toes in) while the passenger side is still straight.
So now with the steering wheel still locked, you go to the passenger side and turn the adjuster 3 turns to make it longer. So now your passenger side tire is point out to the right if you are sitting in the driver's seat, and your driver's side is still pointing in, or is pointing to the right also if you are sitting in the driver's seat.
So what do you do now? You turn the steering wheel to the left to straighten both wheels back so they are pointing straight ahead and you are done..
The hard part for you is to figure out which way to go. Or just pick a direction, and if it gets worse, go the other way.
Benchwrench
Sep 17, 2015 07:56 AM
Daforno
Nevada Chapter
Aug 23, 2015 09:47 AM
Jose A.
Aerostar
Apr 4, 2015 06:42 PM
Reef Tech
Oct 3, 2014 12:20 PM
