Sponsored by: Real Truck
Painted Door handles
Old Apr 8, 2009 | 08:18 PM
02F250SCSD4x4Dgo's Avatar
02F250SCSD4x4Dgo
Like the title says where can i get painted door handles like the ones on the newer f250 Lariats will a newer one work like form an 04 and up i have an 02 what can i buy that will work my truck is white also will the rear doors work from a four door thanks for all the help
Old Apr 8, 2009 | 08:53 PM
Fordfanatic4life's Avatar
Fordfanatic4life
u can paint ur stock door handles...
just needs to be prepped and primered properly for adhesion...
Old Apr 8, 2009 | 09:04 PM
02F250SCSD4x4Dgo
Thats the thing i talked to a paint shop and they told me they could paint them but there was no guarantee that they would stay so saying that i dont want to pay some one to paint them and in a few the paint falls off
Old Apr 8, 2009 | 09:07 PM
Monsta's Avatar
Monsta
Sit. Stay.
I painted mine (see gallery) and they are holding up quite well. It's a DIY job. Use the adhesion promoter and 3 coats a clear coat after & you'll be all set.
Old Apr 8, 2009 | 09:22 PM
02F250SCSD4x4Dgo
can you use this stuff on the mirrors as well thanks
Old Apr 8, 2009 | 09:36 PM
Fordfanatic4life
yes, but be aware mirrors are more likely to chip/peel due to being more in the line for flying debris whilst driving...
sounds like the body shop just didnt want the work.. with proper prepping ur handles will last just as long as the factory painted handles..
in fact if u order a painted handle from Ford theres every chance u could receive a "paint to match" handle anyways.. thats how we get replacement door handles all the time at teh shop i work at..
its common for every car maker to sell unpaintd handles that require being matched to the vehicle in qustion...
Old Apr 8, 2009 | 09:44 PM
02F250SCSD4x4Dgo
Ya i checked on that and they want like 80 to 120 bucks depending on witch ones i get i was also considering using the rear doors off of a super crew i have heard that they will work in the front doors of my truck is this true thanks
Old Apr 8, 2009 | 10:57 PM
jeff7825's Avatar
jeff7825
The only place to get them is the dealer pretty much. Unless you luck out at a junkyard, but they usually won't sell just the handle. I got lucky and got my front ones really cheap from a diesel shop in Nashville, they only had like 3 left when I ordered them back in Nov. of last year. I had to get the rears from the dealer. If you order from the dealer, make sure that you don't order the rear door handles from an Excursion as the rods are different because the rear door is bigger on the Ex than on the Superduty, I found that out the hard way . But I just took the rods off of my old door handles so it was all good.
Old Apr 8, 2009 | 10:58 PM
enduro4231's Avatar
enduro4231
Just get a rattle can of color matched paint, some primer, and some clear and have at it. It won't be resistant to scratches from keys and stuff, but at least it's cheap and easy to touch up.
Old Apr 8, 2009 | 11:26 PM
bayou barataria's Avatar
bayou barataria
Get the paint code and go to the local paint shop that supllies the body shops and they will match the color exactly. If it flakes off, just paint it again it is not that hard.
Old Apr 8, 2009 | 11:54 PM
duetsch65's Avatar
duetsch65
i made the switch on my 2004 and the texture is different. The black door handles have a texture and the painted ones are smooth. I purchased mine from y2k discount ford parts. Not sure if they are still a sponsor but you get a discount.
Old Apr 15, 2009 | 09:39 AM
02F250SCSD4x4Dgo
Do you have a part number from y2k i can not find them thanks
GN1220
Jul 25, 2018 08:38 AM
Gregxlt
2015 - 2020 F150
Jun 25, 2016 08:52 AM
Redneckfordf2502002
Jan 11, 2013 09:50 PM
edouble33
2009 - 2014 F150
Sep 1, 2010 08:22 PM
SteveVFX4
Paint & Bodywork
Sep 17, 2008 11:49 AM
