reusable 6637 ?
Old Apr 8, 2009 | 07:24 PM
yme450's Avatar
yme450
reusable 6637 ?
HI. I remember someone on here that had what i think was a reusable 6637.it looked liked it was made out of the stuff K&N uses. if I'm right who sells them.and how do they hold up.
Old Apr 8, 2009 | 07:30 PM
Pocket's Avatar
Pocket
Any oil conical filter really. AFE, S&B, K&N, etc all make them.
Of course, the filtering quality varies greatly between certain brands.
Old Apr 8, 2009 | 07:35 PM
DieselCamper01's Avatar
DieselCamper01
You also need to be real good about maintaining an oiled filter or it is worthless.
Old Apr 8, 2009 | 08:14 PM
guitarpicr's Avatar
guitarpicr
I thought Brandon (bdrummonds) had one of those a while back
Old Apr 8, 2009 | 08:26 PM
F250_'s Avatar
F250_
Yes... Brandon Drummonds is running one. It is made for AirFlow Systems by AFE, and is hte 5-ply gauze format which is the same construction as the Stage 1 AFE elements. It has about twice the airflow rating as the paper 6637, and is the exact same external dimensions. One of the ways it gets its higher airflow is by having a second filtration cone inverted into the end of the filter.
Here's the ORIGINAL thread link:
https://www.ford-trucks.com/forums/7...ternative.html
Here's the link where Brandon posted his pics:
https://www.ford-trucks.com/forums/7...fe-6637-a.html
Contact information for purchasing one is (the element does NOT show up on the web site... just call:
Dynaflex Chrome Muffler Stacks | Chrome Stacks | Rubber Intake Elbows | Donaldson Mufflers - call them at 1-800-762-9876, or (800) 356-5432
Old Apr 8, 2009 | 08:28 PM
totin_tools's Avatar
totin_tools
I have one also and your right Pete it is an AFE but I cant figure out the part number for it, so I could get a new one.
Old Apr 8, 2009 | 08:31 PM
F250_'s Avatar
F250_
IIRC, you can only get the elements through AirFlow Systems. Dig through those two thread links I posted, though, and you might find an alternative AFE number to order direct.
BTW... why are you getting a new one? Something happen to the original?
Old Apr 8, 2009 | 09:54 PM
JockD's Avatar
JockD
This is a little off topic, but does anyone know just what the 6637 filter was installed on? I checked the NAPA catalog, and it just says various industrial applications. I browsed through the heavy duty & off road catalog, but never found an application for the 6637.
Old Apr 8, 2009 | 10:42 PM
bdrummonds's Avatar
bdrummonds
Original purpose for a 6637 was for a 5.9B and 4BT cummins motors used in industrial air compressors.
Pete, thanks for taking up my slack with the links!
And by the way guys, Pete does make a cover to fit these filters, and it works great.
Old Apr 8, 2009 | 11:20 PM
JockD's Avatar
JockD
Thanks for the info Brandon. That application explains why the 6637 can hold so much dirt while still flowing freely.
Old Apr 9, 2009 | 01:19 AM
strickracing's Avatar
strickracing
the 6637 was also used on cat tractors and dozers
Old Apr 9, 2009 | 06:32 AM
yme450's Avatar
yme450
Thanks everyone and Pete for the links. that is the one i was looking for. now its time to order one.
Old Apr 9, 2009 | 07:46 AM
riverrat41's Avatar
riverrat41
Pete...What is IIRC?
Old Apr 9, 2009 | 08:10 AM
Justin03PSD's Avatar
Justin03PSD
If I Recall Correctly.
Old Apr 9, 2009 | 09:12 AM
F250_'s Avatar
F250_
^^^^ what Justin said.
Brandon, I have only one thing to say in response to your "thanks"...
... I gotcha covered, bro!
... and yes, the pun WAS intended!
