Which one is the rear bed hole??
I'm finishing up on TCI's rear leaf spring kit and I'm changing out the shock cross-member as well. In TCI's instruction, #8, they say to draw a line 29 1/4" from the rear bed bolt hole. I dont have a manual and its been so long since I took the bed off and I'm having trouble figuring out which one is the right hole. PLEASE HELP.
Mark
Mark
Sorry about not being able to post the picture in the thread but I'm not that good.
https://www.ford-trucks.com/forums/a...pictureid=5339
If you take a look at the link it should show the rear frame rail. Is that many holes standard?
Mark
Mark
Hi Mark!, I just came in from looking at my frame...Yea, that last hole appears to be the rear bed crossmember mount hole alright..judging by the Picin your link and what my frame looks like. Short-bed right? 110" wheel-base?
Just for grins I measured from the 'center' of that hole ..to the 'center' rivit of the'original' rear shock crossmember.. I came up with 28 1/4"..is that what you have?
No problem...what 'are ' those extra holes? You might have termites He He..
Again ,just for grins, here are a couple of more measurements
From the center of that that same 'rear' hole...measure fwd 19 1/2"..thats where your 3rd crossmember goes,
Measure( from center of rear hole) 49 3/4"..thats the second cossmember,
(Again from the center of rear hole) Fwd 72 3/8"..on the side of the frame will be an " L " bracket for the fwd most Bed mount( one on each side -thru the wood)
I know it can get tricky with all those holes everywhere and fresh paint covering everything up...good looking project! Keep after it! Good Luck!
Breeze
07-11-2004 01:33 AM
