Sponsored by: Real Truck
10K/14K mod??
Old Apr 7, 2009 | 09:04 PM
enduro4231's Avatar
enduro4231
10K/14K mod??
I have read about the 10K resistor mod being done on diesels, but can it be done on gas trucks as well? Where exactly does the resistor get put in? I understand that it increases injector pressure. Is there a downside to this in a gas truck?
Old Apr 7, 2009 | 10:55 PM
ReAX's Avatar
ReAX
I believe our fuel rails pressure is vacuum manipulated and not electronically as we have a return fuel system. The 05+ may have gone to returnless, but I believe it would be easier to modify the returnless fuel pressure via pcm than wiring.
On the drivers side of the fuel rail is a silver bulb with a vacuum hose leading off it. This allows excess fuel to return to the tank. As vacuum drops, a diaphragm gets shifted and changes the resistance on the valve/seat. There are probably adjustable regulators available, but you will most likely have to saw your reg in half and clamp on the new adjustable top housing. Conversely, you can change out the rails and use an adjustable EFI regulator.
Old Apr 7, 2009 | 10:59 PM
enduro4231's Avatar
enduro4231
I see. So there is no ICP (Injector Control Pressure sensor) like on the diesels? I have however heard of this mod being done to F150's and Mustangs.
Old Apr 7, 2009 | 11:43 PM
ReAX's Avatar
ReAX
The mustangs will have a returnless fuel system at some model change, I think it was 2003 with the 3v motor. In a returnless fuel system, the fuel pump does not pump constantly like our return system. It pumps until the desired fuel pressure is reached and then pumps only to maintain that pressure. I suppose changing the signal from the fuel pressure sensor would cause the fuel pump to cycle longer, however, the same thing can be tweaked in the PCM.
I don't know about the 150s, I guess they could have gone to a returnless style with the 3v motor too. Our 2v motors use a return style fuel system and has a mechanical regulator.
Old Apr 8, 2009 | 07:14 AM
Pocket's Avatar
Pocket
100% totally different fuel injection system. The 10K mod doesn't do a thing to fuel pressure on the Powerstrokes. Instead is bumps up oil pressure. Powerstrokes (except for 08+) use HEUI fuel injection (hydraulic electric unit injection), meaning they use high oil pressure to actuate the injectors. Your 5.4L doesn't use oil pressure to fire the injectors.
patrickke
Nov 24, 2008 11:25 PM
JethroF250
17
Mar 2, 2008 09:49 AM
Erik Sink
23
Jan 13, 2008 05:05 PM
gomfrddy
Feb 13, 2007 02:01 PM
96ford4x4turbodiesel
Nov 6, 2004 01:54 PM
