5.6 K mod
Old Apr 7, 2009 | 06:12 PM
TheTowingCowboy's Avatar
TheTowingCowboy
5.6 K mod
Well I finally know what you guys are talking about and man it soudns so good, I am jsut wondering, how you do it, I knwo it involves the ICP sensor and I watched a guy do it in a video but it was hard to follow, so pictures and really well told steps woulb be appretiated, cause I got a buddy who can get me resistors for free so I will do this at school on thursday if you guys help me out. Thanks guys. Also is it safe to do like a 5.6K?
Edit: Also so if I get free time during easter weekend, how do you set up the resistor on a switch? SO I can flip it on and off when needed.
Old Apr 7, 2009 | 06:47 PM
Brown Falcon's Avatar
Brown Falcon
For the ICP I'd start with a 10k resistor, then move up to a 10k and 4.7k, or a 10k and 5.6k and try it out. Then maybe two 10k's together to make 20k. See which one works best... I dont' remember off the top of my head which wire it is you need to put them on, but look up CoonHunterJoe. He's got pics and stuff...
Old Apr 7, 2009 | 10:11 PM
MissIndependent's Avatar
MissIndependent
spelled with zeroes not o's will make the search faster
i am starting to think maybe i need to try this too lol
Old Apr 7, 2009 | 10:39 PM
MissIndependent
or just go here: https://www.ford-trucks.com/forums/6...on-my-10k.html
turns out i had saved it for future reference
Old Apr 8, 2009 | 10:47 AM
rideracelivemx7's Avatar
rideracelivemx7
this isnt a huge power power mod so you dont have to worry about a switch or anything, theres already limitedspace to work with,butjust get some spade connectors from circuit city,and resistors are only 99cents a package, bu8t you wont notice anythjing with a 5.6, i have a 10k and i barely notice a difference, litte more smoke at park when you goose it, but work from a 10k every truck is different, mine wouldnt take a 14.7 kept throwing a checkengine code, but it would take a 15.6 but i didnt like the idle, and deppending on your truck, the wiremight be different, mine was a green with blue stripe i belive and some other trucks are the wire mentioned, brown with yellow i think? if your looking at the sensor, is the wire facing downward, it forms a smiley face, 2 wires next to eachother and the 3d wire is the mouth, thats the wire you want.
Old Apr 8, 2009 | 05:28 PM
TheTowingCowboy
Okay so start with a 10K and work up? I see, and thank you Miss Independent, I'll give you the run down on it once I have done it and let you know if its worth your time. so 10 and up... hmmm.. Lets go ssomething in the 12 range. I want smoke lol but thanks guys, I'll do a 10K mod.
Old Apr 8, 2009 | 05:59 PM
KevinC.'s Avatar
KevinC.
You need a downpipe and intake first if you have not already done so.
Old Apr 8, 2009 | 06:04 PM
Brown Falcon
and you won't get much smoke at all... a little tiny bit more when in park revving up. Nothing really when you're driving.
The most popular ones people have luck with are 10k, 14.7k, 15.6, and 20k
Old Apr 9, 2009 | 05:16 PM
TheTowingCowboy
Well I did the 15.6K mod today in the auto shop after I put newer tires on my front rims, and man oh man let that baby start upa nd a minute later (At the most) you get that lope, and then when I was backing it out, i put it in drive and hit that gas pedal, got a hop and a squeal, and its great, I so need to do a 6637 next, and a down pipe, I plan on the 6637 soon, but a down pipe... wow thats going to be a while lol, but real quick question... is it bad on the motor to just run a down pipe? Also is there any other DIY stuff I can do to support this mod? Cuase I was imporessed with it, but I knwo there is more I can do to open it up.
Last edited by TheTowingCowboy; Apr 9, 2009 at 05:19 PM. Reason: Spelling and Add-Ons
Old Apr 9, 2009 | 06:16 PM
rideracelivemx7
jsut running a downpipe sounds amazing, sounds like youve got a souped up system, if you just back off the bolts a little so the stock exhaust is still barley attached, its a big enough gap to were it doesnt sound like an exhaust leak and all you can hear is turbo form 1200rpms and up, i did a DP and deleted the cat, all you can here is the turbo, im trying to scrounge up 2ft 3.5 to delete the muff and ill be happy till i get my stacks and chip, youll like the DP, there cheap enough, 130 i belive,cut the cobra head off still attached to the turbo then hack it bottom up ffor easier working conditions, the 6637 is a nice mod, you hear that turbo eating up the air when your matting the beast, i put the stock airfilter meter thing on the pipe i shuved in htere, but every so often it maxes out? not more than 2 weeks on the filter, ohwell. mabe its toclose to the turbo
Nicmike
Nov 26, 2019 09:46 PM
dizzyfingers03
29
Apr 24, 2012 08:23 AM
8525ford
Aug 24, 2009 08:51 PM
2005REDFX4
2004 - 2008 F150
Aug 18, 2009 08:42 PM
RADUD
27
Oct 22, 2008 06:06 PM
