Too much smog crap
Old Apr 5, 2009 | 11:53 PM
tarpless's Avatar
tarpless
Too much smog crap
Hi, I'm new here and was hoping someone could tell me what I need to do to get rid of all the smog crap thats messing up my fine 86 300? Do I need to replace the intake or just remove all the vaccum crap? Any help will be welcomed. Thanks to all.
Old Apr 6, 2009 | 12:49 AM
fmc400's Avatar
fmc400
MSEE
Welcome to FTE. What you're attempting is what ends up causing all sorts of problems. Why do you want to remove it anyway? I'll save you all the details, but everything is set up to work together, and removing one component without compensating with the engine's timing curve and fuel mixture becomes a painful trial-and-error process that, at best, gets you to where you were in the first place.
Old Apr 6, 2009 | 02:59 AM
srercrcr's Avatar
srercrcr
Look at it this way...it ran fantastic when it came off the Ford dealer lot. Nothing wrong with the facrory design. If you're having problems it's cause it needs maintenance or repair.
Old Apr 6, 2009 | 08:50 AM
6CylBill's Avatar
6CylBill
What he said.
Old Apr 6, 2009 | 10:51 AM
AbandonedBronco's Avatar
AbandonedBronco
Generally, those that remove all the emissions equipment and can successfully tune it back correctly (which is difficult since the carb is designed to run with it), gain only a couple horsepower, if any, and no real change in fuel economy.
As complex as the smog system looks, it really doesn't take a lot away from your engine. The easiest way to get your engine running at its best is to be sure all of that equipment is operating correctly.
That being said, I passed emissions with the sniffer test with a brand new cat but without a smug pump or an EGR valve. I had a really hard time getting the engine to run right though. It always bogged at idle, ran too rich at idle, too lean when driving, etc.
If you're looking to fully modify your engine, replacing the intake and exhaust manifolds and putting on a new carb like a 2bbl or 4bbl will bypass all of the emissions equipment. There's plenty of writeups on here in that regard. Just be sure you don't have emissions (and please still put a cat in your exhaust. )
Old Apr 6, 2009 | 06:03 PM
Harte3's Avatar
Harte3
To remove stuff just to remove it rather than repair and maintain as needed is junk auto science. If all the stuff is removed than all the systems have to be re-engineered to non-emissions operation. Do your trouble shooting and repair/maintain as necessary starting with checking for vacuum leaks. The EGR is probably shot/burned out and the Cat is probably plugged or blown out.
Old Apr 6, 2009 | 11:21 PM
tarpless's Avatar
tarpless
Thanks for the responce guys. Perhaps I need to rethink my plans. I thought I would be better off without it but maby not. The smog pump is missing and several lines are pluged with old spark plugs.
Old Apr 7, 2009 | 01:18 PM
Harte3's Avatar
Harte3
Then you may be better off just to finish the re-engineering. An '83 or older carb and have the dizzy recurved for a non-emissions application.
Old Apr 10, 2009 | 09:54 AM
tarpless's Avatar
tarpless
What about the intake? does it need to be replaced also?
Old Apr 10, 2009 | 10:15 AM
AbandonedBronco
If you plan on sticking with the 1bbl, no. But if you want to upgrade to a 2bbl or 4bbl, you'll need a converter for the 2bbl (although it'll be very restricted), and definitely a whole new intake for a 4bbl.
Old Apr 10, 2009 | 03:39 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
There's no re-curving an '86 TFI distributer. He will need to replace it with a DuraSpark II distributer and also add the DuraSpark II module. My '85 has all the smog crap on it and it runs fine. IMHO there is nothing to be gained unless you do everything (4V, cam, compression etc) and then it's up to you to tune it.
Old Apr 10, 2009 | 04:34 PM
1 F150dude's Avatar
1 F150dude
Just do the Dirt Cheap Ignition set up. It cost me less than $100 to the swap on my 84. I was able to junk the TFI distributer and keep the E Core coil. I am running a 75 model duraspark distributer, and a 78 Z28 HEI module. All of the smog system is removed from mine including cats, and it runs great while averaging 20 mpg.
Old Apr 10, 2009 | 07:42 PM
Harte3's Avatar
Harte3
Bern_F150_4x4 and 1 F150dude are correct on the ignition application.
Old Apr 10, 2009 | 07:49 PM
tarpless's Avatar
tarpless
Well to say the least, I have learned a lot from this thread. I just hope I can get it to run as smooth as some of you seem to have yours.
Old Apr 10, 2009 | 07:58 PM
1 F150dude's Avatar
1 F150dude
BTW the 20 mpg is with a messed up feedback carb.
