Bronco II Ford Bronco II
Push Button 4wd
Old Apr 5, 2009 | 06:15 PM
stimmie78's Avatar
stimmie78
Push Button 4wd
I need diagnostic info. Wiring diagrams, pictures, what to test etc. Where are the relays located? I just purchased my 86 bII and the dash and everything is out. I just finally found where to plug in the 4wd buttons. I've got power to the red wire on the connector on the roof. No lights or anything else comes on when I turn on my lights or push the buttons. I'll admit, I'm a GM guy, but I got such a good deal on this rig I couldn't pass it up. This is going to be my fishing/hunting rig for hopefully a few years or longer. All help will be very much appreciated.
Thanks.
Old Apr 5, 2009 | 11:14 PM
rebocardo's Avatar
rebocardo
Invest in a manual transfer case and manual hubs.
Sounds like of it you have the Eddie Bauer edition.
None really for that electronic system. What you need and is probably missing is the electronic control module. It will have about 14 wires going into it and they go everywhere including the clutch switch and NSS.
FWIW: The most common failure in the 4x4 system is the shift motor on the transfer case, It is not known for being reliable ... Next to that the auto hubs. Which is why your hunting rig should be switched to the manual system, plus that would clean up the wiring mess.
Old Apr 5, 2009 | 11:25 PM
stimmie78's Avatar
stimmie78
how hard would it be to do the swap? does the floor have a plate I can take out for the shifter? or am I going to have to use my hvac skills and cut tin? would it be a bolt in swap? no other mods? I just got the thing running, drove it around the block and such. not bad for a $75 ride, but I need to keep it on the cheap.. really cheap to keep my wife happy.
Old Apr 6, 2009 | 02:12 AM
kernel-panic's Avatar
kernel-panic
I don't recall if they have a removable plate for the shifter, but you'd want to get a manual case and shifter from the junkyard - I don't recall if you can remove the electric shift motor and install just the manual shifter and parts. It may take some floorboard cutting - but other than that, it's pretty much a bolt-in swap, from what I understand. Sounds like you scored good, considering. If all the brake parts are still good and in working order and it runs fairly decently, $75 is a darn good steal of a deal, shouldn't require a whole lot of investment other than routine or corrective maintenance....
Old Apr 6, 2009 | 09:55 AM
stimmie78's Avatar
stimmie78
I had to change the lock cylinder because they didn't have keys anymore, and then the fuel pump in the tank. Whatever he had in that tank ate away the rubber hose from the pump to the hard line. It was like tar.
While I was under it doing the fuel pump I looked at the rear brake backing plates and noticed the pin heads looked pretty new. So I'm guessing it's got new rear brakes.
I think I scored very well.
Old Apr 8, 2009 | 02:26 PM
ikarus1's Avatar
ikarus1
the auto x-fer case motor can be manually shifted, from under the truck!
You have to remove the motor first (it's a sealed area even w/o the motor attached...)
Old Apr 8, 2009 | 07:34 PM
stimmie78's Avatar
stimmie78
yes but that would be a pita to crawl under it every time I needed 4wd.
Old Apr 13, 2009 | 04:12 PM
rebocardo's Avatar
rebocardo
No.
Not hard at all.
cjben
Oct 3, 2010 10:28 PM
95FordTruck02
1978 - 1996 Big Bronco
Dec 13, 2009 10:08 PM
Dean88
Nov 13, 2008 10:36 AM
codyingersoll123
Jun 7, 2008 11:10 AM
RSOsborne
1983 - 2012 Ranger & B-Series
Mar 25, 2002 11:47 AM
