headlight that just glows!
Old Apr 5, 2009 | 04:24 AM
kupiec20's Avatar
kupiec20
i noticed that a headlight was out/just glowing -so i replaced the bulb and the new one is doing the samething! any idea whats going on?
Old Apr 5, 2009 | 04:47 AM
tjbeggs's Avatar
tjbeggs
Its either a connection issue with the connector or a ground issue/broken wire.
Old Apr 6, 2009 | 12:11 AM
joe_13894's Avatar
joe_13894
Yep, check the ground. It's either the ground connection on either the bulb connector or the attachment of the wire to the frame.
If you're in low beam, the current follows this path: Power from the switch - low beam filament of dim bulb - high beam filament of dim bulb - high beam filament of bright bulb - ground.
Having all three filaments in series makes the current real low and that's why the bulb is on but dim.
Garrett Killgore
Oct 7, 2016 02:38 PM
xaviar
Feb 29, 2016 07:00 AM
tommyl
Nov 11, 2014 11:18 AM
jonathanpatr
Oct 20, 2014 05:54 AM
RobBroekhuis
Electrical Systems/Wiring
May 18, 2005 04:49 PM
