Valley pan gromet.
Old Apr 4, 2009 | 10:18 PM
George D.'s Avatar
George D.
Valley pan gromet.
Any one know where I can get the turbo drain gromit? The only way i have found to get one is to buy a vally pan. I had a whole valley pan got the gromit out today to put in my 6.9 then when it came time to install the turbo i couldn't find the gromet any where i called around and no luck and our partsless department can't even find a listing. I hade something that might work outo of a cdr seal and some silicone but who knows how long that will last.
Old Apr 5, 2009 | 02:25 AM
David85's Avatar
David85
I'm not sure if anyone here can help you, but I know that the guys in oilburners have the part number and sourced for JUST the valley pan grommit.
Oilburners.net
Old Apr 5, 2009 | 07:46 AM
PLC7.3's Avatar
PLC7.3
ATS would have a grommet part # on their web page for your specific turbo.
Old Apr 5, 2009 | 10:05 AM
99SevenPoint3's Avatar
99SevenPoint3
i had the same problem when i was reinstalling my turbo... i ended up gettin a grommet from a non turbo the one thats attached to the cdr ....well i ended up cuttin the top of that down to id say about an inch or maybe a lil smaller and then using my dremel tool to cut a bit inside of it ...slid on the drain tube clamped it ...and has been that way since with no issues... Just to point out in my case i still had the old grommet that came with the truck but for some reason it would no longer seal and was just pooring out oil...
Old Apr 5, 2009 | 11:10 AM
farmert's Avatar
farmert
The grommets can be purchased from ATS, but they only come in a kit which includes all orings and grommets to install the turbo. The cost for the kit is $60. I just got one to install the turbo on my 85.
Old Apr 5, 2009 | 07:57 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The turbo pedistal grommet has a smaller hole than the CDR grommet does.
So ATS would be the only place since Ford has obsoleted most of the IDI turbo parts.
Old Apr 5, 2009 | 11:03 PM
David85's Avatar
David85
I just realized that if you aren't registered on oilburners than the link I posted will not be visible:
Heres the post in it that matters:
Here's the pics of the factory (093) ATS turbo system VP grommet.
This is one of three brand new ones I got about a week ago.
Give this place a call,
Body Armor Performance Specialists
Their number is 866-408-6812 or 360-604-8555.
I know it sounds weird, but they'll hook you up. Heck, might as well order ya a tac jacket at the same time! Never know when you may need one of those.
Tell them Sean from Highland Automotive Specialties in Nebraska told you to give them a ring, they may remember me, maybe not.
If you regsister, you can see the original thread with attachements as well.
Probably cheaper than going to ATS.
silveradoduane
Apr 7, 2017 11:45 PM
Don Vito
Feb 21, 2017 04:21 PM
brian1080
Mar 21, 2016 07:08 PM
lazyscholar
Jul 30, 2008 09:58 PM
f350custom
Sep 18, 2007 10:28 PM
