cdr valve
Old May 14, 2008 | 07:05 AM
lazyscholar's Avatar
lazyscholar
cdr valve
I have acquired an oil leak and my truck white smokes whenever I go 70+ the oil is on the valley pan is this a bad gromet or o-ring or do I need a new cdr.
Old May 14, 2008 | 07:18 AM
PLC7.3's Avatar
PLC7.3
Do you know when to service your CDR valve?
All 6.9L and 7.3L diesel engines are equipped with a CDR (Crankcase Depression Regulator) valve. Even the new 7.3L Power Stroke is also equipped with the same valve. The CDR valve is one of the leading causes of head gasket failure in these engines. The CDR valve is responsible for controlling the pressure/vacuum in the engine crankcase, and seperating the oil mist from the air and returning the oil to the crankcase. The CDR valve should be serviced every second oil change or when signs listed below are seen.
When the CDR valve is not properly serviced, engine oil enters the air intake and is drawn into the engine. The diesel engine will burn this oil as fuel, however, it is heavier and thicker than diesel fuel and, having greater BTU output, causes excessive heat in the cylinder. Due to the intake manifold design, most of the oil will migrate to #7 and #8 cylinders; the last two cylinders in the rear by the firewall. The increased temperature here will cause the cylinder head to lift off the gasket and allow water or oil to leak out the back of the cylinder head where it meets the block.
To check your CDR valve, remove the air cleaner hold down bolt and inspect it. If the bolt is covered with engine oil mist, it's time to service your CDR valve! Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
To service the CDR wash with a solvent, allow to dry, do not use compressed air to dry. There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
Old May 14, 2008 | 07:43 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The Powerstroke does have a crankcase ventilation system, but it does not require cleaning or maintenance. The CCV on the PSD is nothing more than a small "doghouse" attached to the valvecover that is stuffed with....a brillo pad.... a metallic mesh of some sort anyways. The crankcase gasses/oil mist are always being drawn into the intake. It doesn't become problematic until oil starts leaking from the intercooler boots. Other than rerouting the the vent to atmosphere there is nothing the PSD guys can do to stop it.
Apologies for dragging this thread off topic.
Old May 14, 2008 | 08:01 PM
luthrobediesel's Avatar
luthrobediesel
i believe if the ip is leaking it could run into the valley pan. there is no gasket on it just silicone
Old Jul 30, 2008 | 04:30 AM
86 4X4's Avatar
86 4X4
Smile CDR valve
Thank you for the info this has been on my mind for awile the truck eats a lot of oil and the intake has oil in it so i have one on the way and will install asap
Old Jul 30, 2008 | 09:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
86 4x4,
Welcome to FTE and the IDI diesel forum.
MtTheJeffro
15
Oct 11, 2015 04:56 PM
eraser5
19
Sep 23, 2010 08:40 AM
wreckinball
36
Jul 17, 2010 02:43 PM
wildbill73
Jun 17, 2010 02:05 AM
deanzawistowski
23
Jan 23, 2008 10:17 PM
