ipr replacement not going well...
Old Apr 4, 2009 | 01:02 PM
7.3mule's Avatar
7.3mule
changed my ipr this morning went pretty smooth, but the truck is idling ruff now the directions says that if it does this its not tight enuff... i got the breaker bar this last time and torqued it good, but still ruff idle im taking a beer break and going back at it
Old Apr 4, 2009 | 01:24 PM
Smokin''s Avatar
Smokin'
Smokin
Hmm, that stinks.
Well after your beer, before you tear it out again, make sure the tin nut is tight, too.
Old Apr 4, 2009 | 01:49 PM
SuperDoodie's Avatar
SuperDoodie
Do not overtighten your IPR! You will regret it!
I suspect the reason its running rough is because you lost a fair amount of oil when you removed your old IPR. When that happens it allows air back into the system. Just go drive your truck, it should clear up in about 25 miles of driving.
Old Apr 4, 2009 | 02:06 PM
ron's power stroke's Avatar
ron's power stroke
drive that thing..when you pull the ipr..your letting air into the rails..air= ruff idle
EDIT never mind superdoodie edited his post while i posted..
Old Apr 4, 2009 | 05:29 PM
F350-6's Avatar
F350-6
Well said.
Old Apr 4, 2009 | 06:04 PM
7.3mule's Avatar
7.3mule
you guys were right!! the ol mule is tip top once again... ipr change is done and done...
Old Apr 4, 2009 | 07:43 PM
SuperDoodie
Golfntxnsr
3.8 & 4.2L V6
Apr 28, 2015 07:48 PM
blueline970
Feb 11, 2014 01:31 PM
Deluxe06
15
Jul 26, 2012 04:56 PM
got2befast
Sep 25, 2010 08:06 AM
xavetarx
Feb 6, 2002 07:59 PM
