6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
engine codes help please
Old Apr 4, 2009 | 11:17 AM
szpieleusa's Avatar
szpieleusa
Question engine codes help please
i have P115A, P2269 and P0266 codes from my engine, but dont know what thay mean?
Richard, Europe
2008 F250 6.4
Old Apr 4, 2009 | 11:37 AM
ruschejj's Avatar
ruschejj
You seem to have trouble with Cylinder #2. Here is a link to the code list that I have access to. P2269 is not on here so I don't know what to tell you.
http://www.edgeproducts.com/product_...cle-pdf-41.pdf
Old Apr 4, 2009 | 01:12 PM
szpieleusa's Avatar
szpieleusa
Yep, thanks i found the codes. It looks like i have not workin cylinder 2 injector - as i think.
Old Apr 4, 2009 | 02:39 PM
PowerStrokeHD's Avatar
PowerStrokeHD
The P115A and P2269 DTC's are likely the cause of your P0266 DTC and possibly also the cause of your no start condition...
P2269 - Water in Fuel Condition
Description...
The water in fuel (WIF) sensor is monitored by the powertrain control module (PCM). If the PCM detects water in the fuel, the DTC is set and the WIF indicator lamp is turned on.
Possible causes...
- Water in fuel condition
- WIF circuit short to ground in harness
- WIF sensor
P115A - Low Fuel Level (Forced Limited Power)
Decscription...
Fuel level information is sent from the instrument cluster to the powertrain control module (PCM) on the communication link. If an excessively low fuel level input message is received by the PCM from the instrument cluster, the PCM limits the fuel rail pressure (FRP) and sets DTC P115A.
Possible Causes...
- Empty fuel tank
- Fuel conditioning module circuitry
- Fuel tank control module
- Instrument cluster
- PCM
P0266 - Cylinder 2 Contribution/Balance
Description...
The powertrain control module (PCM) monitors the crankshaft speed and acceleration for each cylinder event. The DTC sets when the acceleration rate of the crankshaft is below or above the calibrated value.
Possible Causes...
- Base engine concerns
- Valve train assembly
- Fuel injector
Old Apr 5, 2009 | 06:48 AM
ruschejj's Avatar
ruschejj
Wow powerstroke: I thought I was being helpful! You win hands down. Great info.
Old Apr 5, 2009 | 01:57 PM
PowerStrokeHD
Its the group effort that makes this community (FTE) what it is...
i eat hybrids
May 20, 2017 10:15 PM
iateatoad
13
Dec 8, 2012 10:35 PM
weberr7
Jul 2, 2012 03:22 AM
woodsman1991
Modular V10 (6.8l)
Feb 3, 2009 03:03 PM
skfleming
1983 - 2012 Ranger & B-Series
Jan 26, 2007 11:58 AM
