95 explorer help please
Old Apr 3, 2009 | 08:11 PM
pinto21632's Avatar
pinto21632
when i go to start it some times it will just click but i would have to wiggle the key or turn it off then back on. it has not done that for 2-3 months but i still have a problem with the radio when i go to start it or turn the key to start the motor plus sometimes after turning the key to acc then start it from acc the radio will blink and it will go am and the clock will go to 12:00 .reset it then it wont do it for sometime then all of a sudden it will do it .three the wipper washer sometimes have to push it 2-3 times then it will spray i dont know if the three things are the same problem or all each a differant problem . any help
Old Apr 4, 2009 | 08:44 AM
mrshorty's Avatar
mrshorty
Starting and radio problem sound like a bad/loose battery cable.
Old Apr 4, 2009 | 08:47 PM
texan2004's Avatar
texan2004
Agreed. Also look at dirty battery cable to battery connections.
Old Apr 6, 2009 | 07:30 AM
marragtop's Avatar
marragtop
Battery cables can corrode from the inside, so examine them carefully.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 15, 2016 06:40 AM
scottlathrop
Oct 3, 2016 01:23 PM
Riddick6464
Mar 31, 2016 09:23 AM
Etidorhpa
May 28, 2012 06:47 PM
superbepro
Electrical Systems/Wiring
Jan 24, 2005 08:35 PM
