Front diff fluid amount question
Old Apr 3, 2009 | 08:04 PM
cjcocn's Avatar
cjcocn
I just changed my front diff fluid and, although I added the recommended amount (1.8L - 3.8 pints), I still cannot feel any fluid when I stick my pinky in the filler hole. I cannot fit my pinky in that far, my ring finger is a size 14 so my fingers are not small.
Am I good to go or should I buy more fluid and add it until I can feel fluid through the filler hole?
My front diff tag reads:
3 73 ?YC35 JB
?610893-1
The question marks represent inverted triangles.
I should have a Dana 50 in the front, correct? I recall seeing a 50 on the diff housing.
Thanks for any suggestions.
Old Apr 3, 2009 | 08:12 PM
DieselCamper01's Avatar
DieselCamper01
I am sure I put in over 2 quarts but cannot remember for sure. Let me do a little digging.
Edit: Here is a link. Says it is a Dana 60. 5.7 pints which if my math is correct is just under 3 qts.
http://www.guzzle7pt3.com/fdiff.php
Old Apr 3, 2009 | 08:21 PM
cjcocn's Avatar
cjcocn
Welcome to guzzle's Front Differential Maintenance Web Page
Thanks for the link. I read it as Guzzle having an F350, which is why he referred to the Dana 60.
I thought that my F250 would have a Dana 50?
Old Apr 3, 2009 | 08:47 PM
DieselCamper01
You may very well be correct. My mistake. I also have a 350. I will see what else I can find.
Old Apr 3, 2009 | 09:00 PM
DieselCamper01
My manual does not tell me there is any capacity difference between a Dana 50 & 60. I think you need to pick up more fluid and fill until it starts to run out the fill hole. My manual says capacity is 5.9 pints
Old Apr 4, 2009 | 08:08 AM
cjcocn's Avatar
cjcocn
That's different from what my manual says. On page 222 (Capacities and Specifications) mine lists the F250/350, Dana 50 axle at 1.8L (3.8 pints) and also lists the F350/450/550, Dana 60 axle at 2.7L (5.8 pints).
Normally I would just fill with 75W-90 until the fluid reached the fill hole, but in this case the manual states that I should only add 1.8L (3.8 pints).
Does anyone out there only run with 1.8L (3.8 pints) in their front diff?
If I put in that extra bottle of gear oil it will only take my fluid level to half (that's where the fill plug is). Will this be too much and cause seals to blow out when I use 4x4?
I am in a bit of a bind here ..... help please!
Old Apr 4, 2009 | 03:22 PM
triskit16's Avatar
triskit16
I think I put 3qts in mine. Ive got the same year and model as you do, Chris. Ive always been told that the fill hole is used to check the level and if its not there you need to add more or see where its leakin from!
Old Apr 4, 2009 | 03:40 PM
clintbonnie's Avatar
clintbonnie
3 73 ?YC35 JB
?610893-1
When you checked the level, was the truck on level ground? It does make a difference..
Old Apr 4, 2009 | 05:08 PM
cjcocn's Avatar
cjcocn
Thanks Tristan! It's good to hear directly from someone with the same truck.
I filled it to the hole and called it good.
Yep. I even turned the truck around 180 degrees just to see if there was a difference.
Thanks for all your help!
Old Apr 4, 2009 | 05:52 PM
triskit16's Avatar
triskit16
No prob!
Its been 2 months since I did mine. I use it quite frequently just to keep everything up to par. Nothing wrong yet!
codybear
Sep 5, 2012 05:25 PM
gtj
Nov 21, 2008 08:55 AM
pintopower8
1983 - 2012 Ranger & B-Series
Dec 7, 2004 12:18 AM
skater
Aug 21, 2002 01:09 AM
tmcalavy
May 19, 2000 09:16 AM
