Front Diff Fluid Volume - Drain Hole
Old Nov 20, 2008 | 08:34 AM
gtj's Avatar
gtj
I changed the transfer case, front and rear differential fluids. Went with Amsoil ATF in the transfer case, because I had some on hand. Used the Ford gear lube in the front and rear differentials. Added the 8 oz. of Friction Modifier for the rear (boy does that stuff stink!).
The transfer case and rear diff took the listed amounts of fluids just filling until it ran out the drain hole, but the front diff took almost 3 quarts before starting to run out the drain hole, when the listed amount is 1.8 liters (slightly less than 2 quarts).
Any another experiences in this regard?
2005 Ex 6.0L Limited 4X4
Thanks
Old Nov 21, 2008 | 07:33 AM
vettdvr's Avatar
vettdvr
1.8 ltrs in incorrect. Be sure to use lubricants that clearly state meeting the ford spec. The front doesn't use synthetic lube, The rear does and this is important due to the heavy load capacities of the truck and wear on the ring/pinion gears. Using fluids that don't meet the spec can cause premature wear out.
Old Nov 21, 2008 | 08:13 AM
JIM_C's Avatar
JIM_C
For the t-case, my book says 1.9L (2 quarts) Mercon V. I changed it last weekend and I put in Castrol's Mercon V recommended for Ford vehicles. Two quarts did not make it run out the fill hole.
I haven't done the diffs yet. I don't tow much so I'm not overly concerned.
Old Nov 21, 2008 | 08:55 AM
vettdvr's Avatar
vettdvr
Sorry mis read the 11.8 as in the front diff. 1.8 is correct for the tx case.
mwrohde
Nov 12, 2012 11:01 PM
Thumper47
1983 - 2012 Ranger & B-Series
Nov 8, 2011 11:27 PM
MoreBoostPlease
Jan 7, 2011 06:57 PM
jjed2007
2004 - 2008 F150
Feb 21, 2008 09:50 PM
geoaigel
1978 - 1996 Big Bronco
17
Mar 23, 2006 09:21 PM
