Opinions on OBS
Old Apr 3, 2009 | 03:14 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Opinions on OBS
ford f - 350 4x4 7.3 deisel nice#######
Hey all, popped down from the 99-03 forum. Found this little gem on craigslist and wanted to know what you all think. I'm not well educated in the 94-97 style, but I know the 7.3 well. Sounds like a nice truck, but i figured i'd ask the experts to this body style. Opinions, comments, things to watch out for? Thanks all
Old Apr 3, 2009 | 04:10 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Looks like a sharp truck. Ditch the BD and get a good tuner/chip and you'd be set. Last week, I had a buddy install a set of 150cc injectors (mini swamps I believe) in my 97 work truck. I have some mild tuning using I believe swamps tuning, and my gosh, that truck really came to life. The truck weighs 13,000lbs, and has 4.56 gears, and I believe it would out run a stock 7.3 with all that weight on it.
Old Apr 3, 2009 | 04:39 PM
STROKIN'IT7.3
O believe me the BD would be gone and a DP would be there without a doubt. I'm assuming its an h2e setup... The only other concern i have is gearing as he doesn't mention it in his post
Old Apr 3, 2009 | 04:46 PM
immastrokinnow's Avatar
immastrokinnow
i dont like those wheels but looks like a nice truck.
Old Apr 3, 2009 | 04:49 PM
STROKIN'IT7.3
I like it too... couple questions
Is this turbo he talks about an H2e? If so, wouldn't stock injectors be laggy with that big thing?
He says 4" exhaust, but i have heard only a 3" downpipe is possible... is this correct.
Anything else to be a concern?
Old Apr 3, 2009 | 05:13 PM
foxracing0934's Avatar
foxracing0934
It does sound to me that it's an h2e and with stock sticks that would be pretty laggy seeing as it's only spittin 90ish cc's. And for $8900 ben from total performance diesel is selling his truck that is imaculate. And has a boat load of upgrades done to it. But your question about the exahust, a 4 inch dp is possible bit with a lot of massaging of the firewall. It's most common for a 3" dp to a 4" exauhst.
Old Apr 3, 2009 | 05:14 PM
MustangMatt96GT's Avatar
MustangMatt96GT
3.5 inch to 4 inch dp is typical. I love my obs
Old Apr 3, 2009 | 05:40 PM
Talyn's Avatar
Talyn
DP Tuners are pretty sweet for the OBS, but the TW's seem better.
The DP tuners work great on the NBS 7.3
Old Apr 3, 2009 | 05:49 PM
BlueMule's Avatar
BlueMule
That's an H2E and it would have a Hypermax 3" downpipe that opens up to 3.5" on the bottom half. Even with stage I's it takes a bit to get it to spool.
Old Apr 3, 2009 | 06:05 PM
Talyn's Avatar
Talyn
that is for sure.
Old Apr 4, 2009 | 02:33 PM
stokedguy's Avatar
stokedguy
what does obs stand for
Old Apr 4, 2009 | 03:11 PM
cnvrtd diesel junky's Avatar
cnvrtd diesel junky
OBS means old body style boss
Old Apr 4, 2009 | 04:14 PM
NWBronco's Avatar
NWBronco
Heheheh, or Powerstroke's Original Body Style....
Old Apr 4, 2009 | 05:44 PM
tjbeggs's Avatar
tjbeggs
Yep H2E. Either he has stock injectors or forgot to mention the larger injectors. Like Rodney said it would spool slow. If it truely does have stock injector a DIY kit can fix that! I think its a sharp looking truck and if its as good as it sounds it a good deal! I would ask about the clutch though. If its the stock clutch it will be on its last legs. If its been replaced ask if its a stock clutch or a single mass conversion. The single mass is better!
Old Apr 4, 2009 | 06:16 PM
KevinC.'s Avatar
KevinC.
Well it says new clutch in the last year and a half, done with ford parts. guessing its still DMF and a stock clutch. With that turbo and if you upgrade injectors youre gonna need an aftermarket clutch. Correct me if I'm wrong.
tailgunn
24
Jan 27, 2015 12:51 PM
Romel77
Jul 27, 2014 11:05 PM
91 Dually
Jul 8, 2014 06:59 PM
banks7.3
Apr 5, 2014 06:15 PM
