10k mod help
Old Apr 2, 2009 | 01:53 PM
rat49f6's Avatar
rat49f6
10k mod help
Today I'm doing the 6637 mod on my early 99
I wanna do the 10k mod also but I have a few questions
1.) Pros/cons?
2.) 10k vs 5.6k?
How to with a switch so I can turn it off???
Thx in advance
Old Apr 2, 2009 | 02:15 PM
superduty4x4's Avatar
superduty4x4
Most SD guys don't see much benefit from a 10k mod. If you want to do it, pick up a 5.6k resistor and a 10k pot. The pot allows you to adjust the resistance to anwhere from 0 to 15.6k, though I can't recall how to wire it up right now.
Short answer- I wouldn't waste your time.
Old Apr 2, 2009 | 05:23 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
I've gotta stupid question. What is a 10K mod?
Old Apr 2, 2009 | 05:27 PM
ron's power stroke's Avatar
ron's power stroke
a resistor thats hooked to the ICP to make it fool the PCM to dump more fuel...kind of like a super chip..but cheaper..get a DP tuner or the like..much safer in the long haul...
Old Apr 2, 2009 | 05:46 PM
12ozd's Avatar
12ozd
That was my question also
Thanks !
You guys are fast !!
Old Apr 2, 2009 | 05:54 PM
SpringerPop's Avatar
SpringerPop
It should adjust the resistance from 5.6K to 15.6K, not zero.
Zero won't work at all.
Wire them in series.
Pop
Old Apr 2, 2009 | 05:56 PM
superduty4x4
Pop
You are right Pop... fingers working faster than brain.
Old Apr 2, 2009 | 05:57 PM
danskool's Avatar
danskool
Go Bills !
Agreed. I tried it. Ripped it out.. Then a month later hooked it back up. To only rip it out and give up. Seen no benefit except a rough erratic idle. A on/off switched hooked up to the go peddle might help so that it will only work when you hit the go peddle ??? . Nah. it won't be me..
wrdabney
6.4L Power Stroke Diesel
Aug 10, 2015 08:24 PM
FlyingZebra34
Oct 17, 2014 07:57 AM
88f1504x4
Feb 9, 2014 04:20 PM
bad ass diesel
19
coreyallan01
Jan 25, 2014 02:59 PM
