Sponsored by: Real Truck
performance f250
Old Apr 1, 2009 | 11:45 PM
hall_393's Avatar
hall_393
performance f250
im new to here so bear with me
17 dont got alot to spare
what i am wanting to do is get some better power out of my 99 f250
while not spending a whole lot of cash
i race mx so i do pull a 28ft race trailer loaded down
(not a every weekend thing jus when i dont have my moms truck lol yes her truck is way bigger)
already have straight exhaust
wat else can i do that is farly priced to get better power
Old Apr 1, 2009 | 11:52 PM
powerstroke72's Avatar
powerstroke72
First, Welcome to FTE! Glad to have you here. You were a little vague on your setup. We're going to need a little more info to try to help you out. What drivetrain (engine, transmission, 4WD or 2WD) do you have in it? There are lot of mods available out there depending upon your drivetrain, etc.
Old Apr 2, 2009 | 12:01 AM
hall_393's Avatar
hall_393
99 7.3L
2wd
90,000 miles
auto
Old Apr 2, 2009 | 12:03 AM
ReAX's Avatar
ReAX
Here's the short list. Any engine is an air pump, more air in and more air out, then pump a little more fuel into it.
So,
Cold air kit to get the air in, exhaust work to get the air out, a computer tune to make use of all this air. After this, you need to start considering what you want out of it. I would say gears and probably a some kind of shift kit or valve body. <BR> Gears will make the truck feel anywhere from 500-2500lbs lighter, but you need to match them to tires your going to run. With stock sized tires, I wouldn't go to 4.56, but with 35" tires, they are nice. With the 35" if you want a more performance orientated feel, 4.88 is a better choice, but it's a little less well mannered on the interstate. Find a gear calculator, put in your tire size and I think 0.74:1 for 4th gear. 60mph is a pretty good speed to set the rpms for, 60mph at 2000 rpms is the good middle ground to low rpm cruise and performance. If you turn more RPMs for 60mph, the truck will feel lighter, if you turn fewer, the truck will be dogged off the line.
Old Apr 2, 2009 | 12:05 AM
powerstroke72
Well, I'll be honest with you and tell you I know a lot more about the 6.0 than the 7.3. That said, have you priced programmers? You also may want to post this here:
https://www.ford-trucks.com/forums/forum31/
This is the '99-'03 7.3 Forum. Those guys have a ton of knowledge and you'll probably get more hits and info there.
Old Apr 2, 2009 | 12:11 AM
hall_393's Avatar
hall_393
ok
thanks guys
Old Apr 2, 2009 | 03:16 PM
capn kirk's Avatar
capn kirk
you have the exhaust set thats first step tuner probably be your next best bet that or an intake but you'll notice alot more from the tuner
Old Apr 2, 2009 | 04:04 PM
enduro4231's Avatar
enduro4231
Edit: I thought you said you had a 5.4L, not a 7.3L. Sorry.
Old Apr 2, 2009 | 04:22 PM
Lubbockguy1979's Avatar
Lubbockguy1979
From what I skim from the 7.3 guys tony wildman is to 7.3 as the sct is to the 6.0.... A chip will do a lot for the truck also the diablo predator is siad to be good on the 7.3. Unless you are running large tires gearing is not going to do anything for you. The exaust, chip will most likely be the best bang for buck upgrades. Much after that is a 6.0 intercooler and some other tech stuff. There are a lot of free mods for the 7.3. I'm a 6.0 guy so I may be wrong but good luck with the truck and the search for hp and speed
Old Apr 2, 2009 | 05:14 PM
capn kirk's Avatar
capn kirk
lubbock is right don't worry about gears unless you get way up in tire size
Old Apr 2, 2009 | 09:04 PM
Furian's Avatar
Furian
You Keep What You Kill
17 years old and has a Super Duty??? Man, I was 46 years old before I got my first Super Duty!
Old Apr 2, 2009 | 09:10 PM
powerstroke72
The trucks are like us, they get better with age...
Madmaxz
Jun 5, 2008 04:03 PM
beforeiforget761
2004 - 2008 F150
19
May 27, 2008 08:30 PM
GT4point6
Modular V10 (6.8l)
Sep 8, 2007 10:27 AM
TigerDan
General Automotive Discussion
May 2, 2005 03:59 PM
cigarxtc
15
Dec 3, 2001 07:55 AM
