Injectors?
Old Apr 7, 2009 | 07:14 PM
Built_Ford_Tough_757's Avatar
I don't know if you would be interested in this or not. But I have all eight injectors. I replaced mine because I thought mine were stuck open. It turned out to be a bad fuel preasure regulator. If you or anyone else wants them, I'll take $100 obo. They work just as good as the new accel injectors I payed $300 for.
Old Apr 7, 2009 | 08:54 PM
baldboyford's Avatar
baldboyford
Like some of the others, fix the code for the spout before you do anything else. I'm not 100% positive, but I believe a missing spout connector or a failure in the spout circuit could very possibly cause the problem you are experiencing. You may end up saving yourself some money by fixing the code first and then check the injectors if needed.
Old Apr 14, 2009 | 11:58 AM
86stepsideF150's Avatar
86stepsideF150
Thank you for all of your constructive comments. I poured a can of Sea Foam in the gas tank, and it didn't seem to solve or even improve the problem with the truck. I am still working on the code 18 problem whenever I get the time. I am going to clear the code and see if it returns since I replaced all of those ignition parts after I pulled the code last time.
IHateCommieCars
Sep 22, 2014 12:11 AM
bozo4ford
Oct 12, 2012 07:10 PM
SaintITC
May 5, 2010 03:16 PM
86Ranger200K
1983 - 2012 Ranger & B-Series
Apr 6, 2007 04:22 PM
allengoodwine
13
Dec 3, 2000 10:58 PM
