Alignment Question
Old Apr 14, 2009 | 11:32 AM
qkpicker's Avatar
qkpicker
Alignment Question
I just bought some used tires and rims and it really shows how poorly my tires are aligned. When the driver's side wheel is straight with the body the passenger wheel is turned in (as if you were making a mild left turn). I want to adjust the alignment before driving it to a shop to have it done professionally.
My question is: After looking under the truck, in order to extend the tie rod, is all that I have to do is loosen to two bolts/nuts on the bands around the tie rod adjustment sleeve and then spin it in the apropriate direction??
Thanks,
Old Apr 14, 2009 | 11:41 AM
bashby's Avatar
bashby
yes, thats all there is to it, they stick though so you may not be able to turn them
Old Apr 14, 2009 | 11:52 AM
qkpicker's Avatar
qkpicker
Is it easier to do with the wheel jacked up or will it still adjust with some force while the wheel is on the ground? I would rather have it on the ground so I can get a good look at the angle of the tire.
Thanks,
Old Apr 14, 2009 | 11:55 AM
bashby's Avatar
bashby
on the ground is fine
Old Apr 14, 2009 | 12:13 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Jack it up, Spin each wheel and take a pencil or marker and scribe a line all the way around the tire... Put it back on the ground and measure front and rear on the lines and adjust accordingly. Measure at the same point above ground.
-Enjoy
fh : )_~
