Sponsored by: Kumho
Death Wobble!!!
Old Apr 1, 2009 | 06:58 PM
Blue Rebel's Avatar
Blue Rebel
Death Wobble!!!
Hey, bought a new truck about a week ago, its a 95 w/ 6" BDS suspension lift, 33" BFG ATs and 15x10" wheels. Noticed while driving over bumpy roads it would get the dreaded "death wobble." OK, i can fix that, just gotta find out whats loose. Crawled under it, and checked EVERYTHING. Only looseness i could find was in the gearbox. Researched it, and adjusted out most of the freeplay. (Kinda scared to go too far) Went for my test drive, and now its worse!! I get the death wobble going over certain roads between 33-43mph. Any ideas what could be causing it that is not loose componants? Would worn out shocks cause this? Thanks for any help!
Old Apr 1, 2009 | 11:51 PM
fixnair's Avatar
fixnair
Probably tire wear. When I get it I rotate the tires and that usually cures it for some time. The front tires cup and that sets it up.
Old Apr 2, 2009 | 12:02 AM
flamebuster's Avatar
flamebuster
check the ball joints. Jack up one side till tire is a good inch or more off the ground and use a 2' pry bar and lift up and down on wheel you will be able to tell real quick if they are bad. turning the wheel a little makes it easier to see around the tire to see which ball joint is out. then repeat on other side.
I assume you had some one move the steering wheel back and forth while you looked at pitman arm and idler arm along with tie rods.
Old Apr 2, 2009 | 03:09 AM
Blue Rebel's Avatar
Blue Rebel
Yup, already checked the ball joints, and yes, had someone rock the wheel for me. Gonna take it in tomorrow and have the tires rebalanced, rotated, and have the alignment checked.
Old Apr 3, 2009 | 01:03 AM
CE-f250's Avatar
CE-f250
My F-250 had the "death wobble" and new shocks did fix the problem.
Old Apr 3, 2009 | 02:50 AM
Blue Rebel's Avatar
Blue Rebel
Update: Got the truck in to have the tires balanced/rotated, they took off the fronts, and on the drivers side there were 2 washers spacing the rim away from the hub on each stud!!! Took them off, got the tires balanced, and its much better. Still get the death wobble, but it takes more to set it off. Gonna have the alignment done next.
Old Apr 5, 2009 | 09:54 PM
*2fords*'s Avatar
*2fords*
A 6" lift is enough to mess up your steer geomotry. Unless the kit came with all the drop brackets, longer Tie rods, etc. Nothing is sitting where the factory designed them to be.
TruckU on Speedtv. Has done A show on this. It could be any combination of things from bad front bearings, ball joints loose rod ends steering damper. etc. the list could go on and on.
Old Apr 15, 2009 | 06:55 PM
MUSKY1011's Avatar
MUSKY1011
just repalce everything on the front end
Old Apr 15, 2009 | 07:48 PM
Blue Rebel's Avatar
Blue Rebel
Sorry i forgot to update this. when i first had someone rock the wheel for me, it was my 11 year old sister. Turns out she wasnt rocking it hard enough. Had a buddy do it again, and one of the ttb drop brackets was loose. Replaced all the mounting hardware, and no more death wobble.
kenwc
Oct 18, 2013 04:43 PM
captain1997
Sep 18, 2011 05:33 PM
hatchet
Offroad & 4x4
21
Feb 22, 2011 05:01 AM
cadunkle
17
Jan 23, 2009 03:58 PM
ford4x4offrd
22
Apr 17, 2002 10:39 PM
