1978 - 1996 Big Bronco
300 mpg
Old Mar 31, 2009 | 10:42 AM
trrh's Avatar
trrh
300 mpg
I need help. i have a 1988 bronco 300 i6 with 5 speed, The engine is new - not a rebuild. Has headers, free flow exhaust, throttle body spacer, cold air intake. Cam is from Cliffords with their valve springs. I shift about 2,000 rpm and I can only get about 11 mpg in town and 12 to 13 on highway- any suggestions
Old Mar 31, 2009 | 10:48 AM
Conanski's Avatar
Conanski
What size tires are on it and what is the rearend gear ratio?
Are there any codes present?
Old Mar 31, 2009 | 12:32 PM
trrh's Avatar
trrh
it doesn't show any codes, tires 31x10.5x15 and gear ratio 3.73
Old Mar 31, 2009 | 12:48 PM
AbandonedBronco's Avatar
AbandonedBronco
Have you checked simple things, like changing the cap/rotor/fuel filter, etc? I know the engine is new, but sometimes these things might just be switched from one engine to the next.
Also, check to be sure the parking brake isn't sticking, that'll really put some drag on your system.
With your setup, 11 isn't SUPER bad in town, but you should be getting around 13 - 14. On the highway, you should be getting 17 - 20, esp with a new engine and a 5 speed.
This might also be better posted over on the 300 forum: https://www.ford-trucks.com/forums/forum52
You can also do some preliminary searches over on that forum, as MPG are discussed a lot.
Old Mar 31, 2009 | 02:07 PM
bertha66's Avatar
bertha66
Tight new engines will not get as good MPG untill it has a few miles on it. IMO
Old Mar 31, 2009 | 03:55 PM
Kemicalburns's Avatar
Kemicalburns
I agree with Bertha
how many miles on the motor so far? is this efi or carbed?
Old Apr 2, 2009 | 10:05 AM
trrh's Avatar
trrh
the new engine has about 2500 miles on it. it is EFI speed density. I've thought about going to MAF and have some of the parts. I could live with around 13mpg in town and 16 to 17 on highway. I just can't figure out why I don't see much change between highway and city. The engine also runs on the cold side of the normal range and the oil pressure is on the high side - thanks
Old Apr 2, 2009 | 11:10 AM
Kemicalburns
what temp Tstat did you install? the cam you installed by clifford was it a speed density friendly cam? 2500 miles is hardly broke in yet. are you following the proper break in procedures on the motor? I would also pull codes to see what the computer thinks is going on. fordfuelinjection.com has instructions on this process using a paperclip
Mdennis0_8
35
Feb 23, 2024 07:13 PM
dylansf23
Apr 30, 2014 01:07 PM
zogmon
19
May 19, 2013 02:22 AM
rb76543
Jun 26, 2010 06:23 PM
erooms
Dec 9, 2003 10:03 PM
