Electrical issue 1992 EB bronco
ffice
ffice" /><o
></o
>1. My warning buzzer for lights, door ajar does not work<o
></o
>2. Courtesy lights do not come on when the drivers do is open (but do when passenger door is open)<o
></o
>3. Power mirrors will not work.<o
></o
>4. Map lights will not work (dome light in center does)<o
></o
><o
> </o
>I have replace the bulbs in the map lights, replace the mirror switch on the drivers door, replace the courtesy light switch in the drivers door jam and check all fuses, that I know of. I don’t have an owner's manual and can’t find one, so I don’t know what else to replace, could it be a relay and if so, how do I know which one? I just had the motor and trans rebuilt so I am trying to fix a few things myself. Thank you in advance for your help.<o
></o
Is there power to the switch (chime etc.)?
Does power flow through the switch?
Follow circuit to next switch and test in the same manner.
Your just gonna have to investigate.
