will it work
Old 03-30-2009, 11:40 PM
cgrant's Avatar
cgrant
cgrant is offline
will it work
i was wondering if u can put a cam from a 90s model 351w into one form the 80s and will gt40p heads work on a 351
Old 03-31-2009, 01:36 AM
fordeverpower's Avatar
fordeverpower
fordeverpower is offline
as long as both are hydraulic but in mid 90's the 351w got roller cams.
Old 03-31-2009, 04:21 AM
kernel-panic's Avatar
kernel-panic
kernel-panic is offline
You want to be careful mixing and matching. Not saying it can't be done, but the cam has to match the rest of the valvetrain in most cases. I've seen solid lifter cams used with hydraulic, and either of those used with roller lifters, but that was people with a heck of a lot more experience than me doing the build-up. The heads should fit - and if they are 'stock' equipped with roller lifters and the cam is a roller cam, it should be fairly straightforward.
Old 04-08-2009, 11:09 PM
doug1222556's Avatar
doug1222556
doug1222556 is offline
GT40-P heads can cause some real issues with certain headers or manifolds. Might want to research that a bit. If you are talking about taking a used cam from a 90's block and putting it in an 80's: #1 if it's a flat tappet cam it needs to be low miles and you must use new lifters. #2 if it is a roller cam, the 80's block won't be machined for it. #3 just get a new cam that's fitted to your set-up.
Old 04-09-2009, 01:58 AM
fordeverpower
yeah the exhaust is an issue but so are the head bolts, 302 are 7/16 and 351's are 1/2
Old 04-09-2009, 04:10 AM
lew52's Avatar
lew52
lew52 is offline
Yes if you put a set of 302 heads on a 351 you will need to drill them out ..Lew
Old 04-09-2009, 06:18 PM
petes79f150's Avatar
petes79f150
petes79f150 is offline
FWIW- NEVER use a hydraulic cam with solid lifters (or vice-versa)- the ramp acceleration rates are different and will munch a cam and usually everything else in the vicinity in a hurry. Same goes for hyd.flat and hyd. roller cams. The ramp speeds are very different. Use the appropriate cam and lifters to match.
Pete
PS- Nice avatar Matt...
Old 04-09-2009, 09:43 PM
fordeverpower
now it is possible to run solids on a hydraulic cam but its not best for the average person to try it.
I like the avatar and i give credit where its due in my sig.
Old 04-21-2009, 07:41 AM
PRL's Avatar
PRL
PRL is offline
When interchanging the cam, make sure the firing orders are the same. I ran into this problem when I did an engine swap...
marcoelam
07-11-2014 02:29 PM
Brown_Jonathan89
10-25-2012 08:06 PM
ncl
18
09-30-2012 10:22 PM
relient3074
05-21-2008 07:24 PM
j30rdesign
18
08-01-2004 12:21 AM
Quick Reply: will it work
