Welder Question
Old Mar 30, 2009 | 09:54 PM
drof46's Avatar
drof46
Make sure it works and you can't go wrong for $125. Make him throw in the helmet and any rods he has. Might even talk him out of some gloves.
Old Mar 30, 2009 | 10:40 PM
Shorty 66's Avatar
Shorty 66
7014= AC/DC +/- used for general welding on about 3/16 or thinner
7024= "dummy rod" 3/16 or thinner
7018= just about any thickness neduim and high carbon steel a good all around rod AC/DC+
6013= AC/DC +/- used for sheet metal and thin material low amps used
6011= AC/DC +/- used for greasey or dirty metal deep penetrating rod
6010= DC+ good for vertical and overhead welding on dirty metals also a deep penetrating rod
9018= AC/DC+ used mostly in the pressure vessel field boilers and pipe also
please correct me if I'm wrong with these, it's been a while since I stick welded.
Old Mar 30, 2009 | 10:46 PM
flipklos's Avatar
flipklos
Shorty 66 damn close, damn close. 7024 is a production rod replaced by wire
6011 is a shallow penetrating rod with fast freeze properties used primarly for root passes on groove welds and as a tacking rod. It's AC/DC compatable.
6010 is the same as 6011 but is only DC compatable.
6013 is a general use rod designed originaly for AC welders and use in the farm world.
7014 is a general rod that is rarely used anymore. I belive it was originaly designed for use in ship manufacturing and offered high deposition rates.
Id let ya weld.
Old Mar 30, 2009 | 11:09 PM
Shorty 66's Avatar
Shorty 66
Thanks, I use to work for a old welding instructor/farmer. old skool. Learned alot from him. Thats where I did most of my stick welding. Now it is Tig.
Old Mar 30, 2009 | 11:12 PM
flipklos's Avatar
flipklos
Tig rocks. Thats all there is to say. I learned more in two months with an oil field welder then in 8 months of welding school. College is good, but overated.
Old Mar 31, 2009 | 08:49 AM
Shorty 66's Avatar
Shorty 66
Same here. I went to a local votech school for welding and I learned more from the old boy I worked for than I ever would have learned in school.
cosmaar1
Oct 17, 2014 11:41 AM
Anafiel
Jan 23, 2011 10:10 AM
gschwoyer
Garage & Workshop
Aug 18, 2005 07:32 PM
51dueller
Garage & Workshop
Jun 4, 2005 03:29 AM
f-4x4
Garage & Workshop
51
Dec 25, 2004 09:31 PM
