Welder Question
I know there are personal preferences involved, but generally what is the best type of welder to start with.
I have a chance to pick up a Miller 180 (stick) welder for cheap, but I don't know if that's what I should even begin with.
Honestly, I don't even know the difference between a MIG & a TIG.
Any insight would be appreciated.
Thanks, Bob
How to MIG Weld | Expert Village Videos
These are free videos all about the basics and techniques of Mig welding.
Arc (stick) welding is a very strong form of welding that requires a moderate level of skill. In automotive use it is best used on frame welding and fabrication of flatbeds, brushgaurds, and hitches. Durable and strong. Reasonably easy to use it has a large heat output and high deposition rate. Some people can weld sheet metal with it. They learned how to do that by running stick for 25 years in all enviorments. The main benifit to sitick is its all weather ability. As long as the rod stays dry you can weld in a 50mph wind, the rain, and in some cases through oil/water/rust/grease.
Save that for heavy fab jobs or fixing shovels.
MIG or wire welding.
Easiest to learn and has high adaptability. I've welded stainless, alumanum and carbon steel with mig. Thicknesses ranging from 3" plate to 22 ga sheet steel.
Select the corect wire and gas, size is a factor, youll need to choose wisely.
.023 and .030 are usualy used for body welding use 95/5 gas.
.035 is a common fab wire. reasonable deposition with good heat control use a 90/10 gas.
.045 is for production work and heavy fab. High deposition and great penetration. 90/10 is commpon as are 75/25 and other mixed gases.
By a quality wire. Lincoln makes great products for wire. ESAB is ok too.
MIG would be best for the begining welder. 5 hours with a decent teacher and one can be reasonobly proficent in the flat position. Vertical, horizantal and overhead are more learned from personal techneque. That is the best bang for your buck. Videos and a teacher are helpful but practice, practice, practice. I've been a welder for 5 years now and I still dont know it all, and I do it for 40-50 hours a week.
Good luck and sorry for draging on.
Patrick Henry: “Guard with jealous attention the public liberty. Suspect everyone who approaches that jewel. Unfortunately, nothing will preserve it but downright force. Whenever you give up that force, you are ruined...The great object is that every man be armed. Everyone who is able might have a gun.”
had an urge to chime in and add my $.02. Came across an article in Classic Truck Mag. on MIG welding may find helpful. Seem to recall simular on MIG, and or TIG in one of my issues of CarCraft, can go to both websites and search their tech articles.
Mig Welding 101 - Classic Trucks
The little 110 is fine and dandy for putting body panels in.
Try welding 1/4" plate and youll be disapointed.
I've been taking all your different insights and trying to decide on buying this unit as a starter. I agree after hearing from a few people on here and at work, the the MIG is the easiest to learn and use. I really liked the comment about "learn on a stick"...makes a lotta sense. I know as well, the 'ol..."you get what you pay for". So yeah, decisions, decisions.
I've been taking all your different insights and trying to decide if I should buy this unit as a starter. Or should I just wait and buy MIG. It seams like MIG would be more suited for my lack of skills at this point.
Here's the info I have on the unit available,
let me know if you think it's a good deal.
Thanks Everyone !!
~Bob
It reads:
I have for sale a Miller 180 Welder (stick). I purchased this used from a friend last fall and have not used. It was working the day I purchased it and has only collected dust in my garage - so all should still be good.
It says it is 230 volts and 37 amps, has the same style plug as an rv/camper.
<img src="http://img.photobucket.com/albums/v737/ynkstr/welder.jpg?t=1238455528">
<img src="http://img.photobucket.com/albums/v737/ynkstr/welder3.jpg?t=1238455984">
<img src="http://img.photobucket.com/albums/v737/ynkstr/welder2.jpg?t=1238456107">
Arc welding is actualy simpler to do, and in many aplications easier. It is more difficult to be proficent and requires more technical knowledge than mig welding.
Here lets try this..
What is the correct use for these rods?
7014
7024
7018
6013
6011
6010
9018
What is the amprege used? On what thickness? AC/DC? Stick can be used on body metal. Its difficult though.
Mig its just 60 series mild wire 65/5 gas tune your heat and go. That welder shown is an AC only box and would be a good deal at $140 if it runs Miller is the best in the industry.
As a houshold maintannce welder it would be great. That is not a good piece for welding an auto body though.
If you buy it PM me and Ill be happy to awnser any questions you have.
Just make sure it runs.
