6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cold engine tick
Old Mar 29, 2009 | 08:55 AM
deadbug's Avatar
deadbug
Cold engine tick
I read awhile back someone mentioned hearing a ticking noise when cold. then once warmed up it was gone.
I tried a search but couldn't locate it.
This is on the driver's side hear at a drive threw then after a few more miles it's gone.
So has anyone else experienced this, and is it anything to worry about ?
Sounds just like a piston, but I remember something about a belt of fan maybe
tia
Old Mar 29, 2009 | 09:11 AM
dertdrag's Avatar
dertdrag
Mine used to do it, so I turned up the radio and it went away. This solution has worked well for me for a lot of issues, both mechanical and marital.
Old Mar 29, 2009 | 11:57 AM
firemansdiesel's Avatar
firemansdiesel
Mine has a tapping noise (than a ticking noise) when cold at times at idle (not always). When up to operating temps or cruise speeds, it goes away. I am not worried about it until there is a recall/TSB out for it (nothing really you can do on Fords part now). Started after the first oil change.
Sad to say, but it is under factory warranty right now (I also have a extended warranty on my truck) so that is why I'm not too worried about it. If the engine grenades it's on Ford. If I keep having problems associated w/ it. Then I will have them buy it back and get a new truck.
Old Mar 29, 2009 | 03:14 PM
rmosso1's Avatar
rmosso1
firemansdiesel:
EASIER SAID THAN DONE.
Old Mar 29, 2009 | 05:04 PM
rock_doctor's Avatar
rock_doctor
It is normal. Ford and GM say it is normal and all diesels make this harmonic tick. The only difference from past diesels is the new ones are so quiet you can actually hear it. Ford has a tsb out about it, that just explains what the tick is and says to do no repairs as it is normal and no amount of repairs will fix it. My truck has the tick and it is a week old.
Old Mar 29, 2009 | 05:41 PM
firemansdiesel
Originally Posted by rmosso1
firemansdiesel:
O'Really?.?
Old Mar 29, 2009 | 05:58 PM
ctownson's Avatar
ctownson
this is a common issue and unfortunately there seems to be no solution - I like the "radio" approach. Mine also goes away as soon as the engine is warm
Old Mar 29, 2009 | 09:11 PM
sawtooth's Avatar
sawtooth
tia
One thing to check even though it may not be your issue. Start the engine from cold one morning and get out of the truck. If the noise comes from the front of the engine area then you probably have the noisy idler pulley issue. I had this and it kinda sounded like a tick. It was replaced and i've not heard the noise since.
cornfiled stroker
6.7L Power Stroke Diesel
Aug 26, 2013 07:33 PM
davbeisner
Nov 16, 2012 05:08 PM
JamieMueller
Modular V10 (6.8l)
17
Sep 13, 2011 07:01 PM
Yogi-96blazer
20
Feb 25, 2006 06:53 AM
kodiakmook
1997 - 2003 F150
19
Apr 19, 2005 08:17 AM
