Bronco II Ford Bronco II
bearings
Old Mar 28, 2009 | 06:45 PM
61eline's Avatar
61eline
bearings
Hi guys Im doin a top end on a 289 cam heads etc checked bearings to be safe showing signs of wear on one main and several rods .should i replace with stock size bearings or .0001 ? thanks Mick
Old Mar 30, 2009 | 07:48 AM
kernel-panic's Avatar
kernel-panic
might want to ask this over on the general engine board.
Old Apr 1, 2009 | 07:37 PM
Tedybear's Avatar
Tedybear
Doing the top end....or the bottom end...or both?
Regardless, if we are talking crankshaft? Run the test with the plastic-gauge stuff....give it a shot with the stock sized bearings. Unless something 'spun' or the crank has been machined before? Stock should be within range. (if not? Time to talk with a machine shop/engine rebuild shop...might need to have the crank machined and bearings matched)
S-
Old Apr 5, 2009 | 08:28 PM
61eline's Avatar
61eline
thanks
thanks for the replies crank looks good found half of a cam bearing in the oil pan tho looks like its going to machine shop
bassn1
May 25, 2009 06:42 PM
Chumbucket
Mar 16, 2006 04:40 PM
JJDDOOGG
Nov 27, 2002 12:18 PM
Drawsoncad420
Aug 10, 2002 05:07 PM
FortyFords
Jun 10, 2002 05:59 PM
